BrianO Offline Image Upload: On
p.1 #9 · Recommendations for bargain off-camera flashes? | |
pollux114 wrote: Cool, thanks guys. The vivitars and old sb's were at the top of the list...
I second the motion for the 285HV.
I got my first one in 1975, when it was the shoe-mount that everyone wanted. The one I have now is a newer one that I've had for 15 years or so. I never use it as an on-camera flash since the sync voltage on some pre-2007 models can fry the circuits of digital cameras, but that's what my 580EX is for. (If you want to use one on-camera, you can check the sync voltage with a voltmeter, and if it's above 6 volts you can run it through a Wein Safe Sync adaptor.)
I use the 285 strictly for off-camera use. I have the extension cord for the automatic sensor module, and a hot-shoe adapter with optical slave trigger. Over the years I've lost the hard-plastic filter set that I had (several colored filters and a wide-angle diffuser), and unfortunately I haven't seen any for sale in stores or on e-Bay.
For less than $100 it's a hard flash to beat. It has a guide number of 140 feet @ 100 ISO in the tele position, it has four automatic ranges for various f stops, and it has four manual power levels (full, 1/2, 1/4, and 1/16).
It has a neat "circular slide rule" distance calculator built in that adjusts for the different zoom settings when you extend or retract the head, so you don't have to do any guide-number-versus-distance algebra in your head. (Contrary to what some have written, the dial doesn't actually change the power of the flash; it's just a calculator. All power/sensor adjustments are done by rotating the sensor ring on the front of the flash.)
Here's a link to a review: http://www.popphoto.com/Reviews/Accessories/Vivitar-285HV-Review
I highly recommend this flash, and I'm going to buy a couple more for myself.
