Archive 2009 · Sony adapters for old Zeiss
bigreen505
p.1 #1 · Sony adapters for old Zeiss
Does anyone make Contax to Sony adapters? I would love to be able to try some Zeiss optics and can't currently afford the Sony/Zeiss lenses.
I'm moving over from Leica R and will use Leitax adapters for my 15/3.5, 50/2, 90/2 and 180/2.8. However, my 35-70/4, which was my main lens, is not adaptable. I will probably add either a 28 or 35 to fill the hole. I would love to try the 28-70/3.5 Zeiss.
Jun 29, 2009 at 11:47 PM
mawz
p.1 #2 · Sony adapters for old Zeiss
Leitax is likely to introduce Contax mount conversions for Alpha. That will be the best option. There currently is no infinity-capable adapter which doesn't include optics. I've looked at the issue briefly and it doesn't look too difficult to convert a Contax lens which has the bolt-on bayonet lugs to Alpha mount using a modified M42 adapter. Most of the Zeiss lenses have the removable bayonet lugs.
Note there is no 28-70 f3.5 Zeiss. There is a 35-70 f3.4 and a 28-70 f3.5-4.5 however. I recommend the 35-70 as the 28-70 is merely average in comparison.
Also note the ZS 35mm f2 is easily adapted as it is a M42 lens. Not cheap however.
Jun 29, 2009 at 11:51 PM
JimU
p.1 #3 · Sony adapters for old Zeiss
how about that famous 21/2.8?
Jun 30, 2009 at 04:28 AM
ayler
p.1 #4 · Sony adapters for old Zeiss
Leitax has a first batch in manufacture as we speak, so it should be out quite soon. The list of lenses will be the same they convert to Pentax to start with: only MM and narrow mount; the 21mm Distagon is on the Pentax list, do it should be convertible to Sony. Don't shoot the messenger if it comes out slightly differently!
http://www.leitax.com/zeiss-contax-lens-for-pentax-cameras.html
Jun 30, 2009 at 08:40 PM
Tariq Gibran
p.1 #5 · Sony adapters for old Zeiss
Wow, that is great news. Time to go shopping!
Jun 30, 2009 at 09:32 PM
