Archive 2009 · 21mm Contax Distagon C-Polarizer
ziyadj
p.1 #1 · 21mm Contax Distagon C-Polarizer
Hi there
I was wondering if anyone had experience with a circular polarizer on Contax 21mm Distagon using FF camera. I have a 5D MkII and was thinking of getting the B+W 82mm Kaesemann MRC Circular Polarizer (non slim, w front threads). I want a filter that will not cause vignetting. Any suggestions or advise would be appreciated.
Thanks Ziyad
Jun 26, 2009 at 03:28 AM
dbiela
p.1 #2 · 21mm Contax Distagon C-Polarizer
I shot a B&W circular polarizer a few times with the 21, once I shot on a very sunny clear day and I found that with my angle to the sun/sky an area of the sky was extremely dark and I had a better image with out it. The lens is just so wide and I had so much sky in the shot that there was just always some part of the sky that be too dark for my taste, The filter was a thin type with out front threads and I did not see a problem vignetting. I tried a standard Hoya and did have problems with it.
Edited on Jun 26, 2009 at 06:06 AM · View previous versions
Jun 26, 2009 at 06:04 AM
PSquared63
p.1 #3 · 21mm Contax Distagon C-Polarizer
That's the CPL that I use. If it worsens vignetting, it's not very noticeable. However, adding the W1 hood on top of the CPL will introduce slight vignetting.
The following are from 5DM2 + CZ Distagon 21/2.8 for Contax mounted using a Cameraquest adapter.
#1 f/8 bare (with and without the hood look the same)
#2 f/8 + CPL
#3 f/8 + CPL + Hood
Hope this helps.
Jun 26, 2009 at 06:05 AM
ziyadj
p.1 #4 · 21mm Contax Distagon C-Polarizer
Thanks Dennis and Peter. That was very helpful.
Jun 26, 2009 at 08:59 AM
ken.vs.ryu
p.1 #5 · 21mm Contax Distagon C-Polarizer
would a linear polarizer work as well?
Apr 08, 2010 at 06:22 PM
CPWarner
p.1 #6 · 21mm Contax Distagon C-Polarizer
I have a 105mm slim mount circular polarizer that I use with my Lee system. I works with my Contax Distagon 21mm and 18mm on my 1DSmkII with no vignetting. That said, the previous comments about sky do apply. However I do find the polarizer useful when photographing streams or water where I may not have sky and want a wide angle perspective.
Apr 09, 2010 at 11:18 PM
thrice
p.1 #7 · 21mm Contax Distagon C-Polarizer
Of course, but the camera might not be able to focus confirm or accurately meter.
Apr 09, 2010 at 11:44 PM
ken.vs.ryu
p.1 #8 · 21mm Contax Distagon C-Polarizer
I was afraid of that, thanks!
Apr 10, 2010 at 07:27 AM
fit ti be tied
p.1 #9 · 21mm Contax Distagon C-Polarizer
I wonder if it would make a difference if you used say a 95mm CPL with a step-up adapter?
Apr 10, 2010 at 01:51 PM
jaclarkaus
p.1 #10 · 21mm Contax Distagon C-Polarizer
Or buy a Lee filter system with a wide angle adapter
Apr 10, 2010 at 09:21 PM
