fredmiranda.com Login
This topic is in the 2009 archive. You can read it and like its posts here. It is read only.
Archive 2009sb600 vs sb900
codeninja
p.1 #1sb600 vs sb900
What am I missing if I get sb600 over sb900? I don't plan on doing any sort of studio shots and the flash will be always on the camera. Is the diffuser for sb900 works better than typical sto-ffen one? How much more powerful sb900 is?
Jun 01, 2009 at 04:02 PM
panos.v
Details
p.1 #2sb600 vs sb900
You lose the power, the beam controls, 200mm zooming and the master CLS functionality.
For the difference in price, I'd really have to need the above to go for a SB900.
Jun 01, 2009 at 04:23 PM
codeninja
Details
p.1 #3sb600 vs sb900
could you elaborate the beam control and 200mm zooming for me please?
Jun 01, 2009 at 04:30 PM
codeninja
Details
p.1 #4sb600 vs sb900
How far sd-600 can reach with max zoom?
Jun 01, 2009 at 08:44 PM
Avi B
Details
p.1 #5sb600 vs sb900
the sb900 has better UI too!
beam control is light shaping at the source...
200mm zooming means the flash zooms out to 200mm... most flashes go out to 135mm... new to flash are you? if so, have a look here.
Jun 01, 2009 at 09:18 PM
nikt
Details
p.1 #6sb600 vs sb900
I'm going to say, if you know the size of the SB900, and you know the cost, and these things are not issues, then get the SB900. Pick a function, and it will be better than the SB600. Afterall, it's just money.
Jun 01, 2009 at 09:39 PM
codeninja
Details
p.1 #7sb600 vs sb900
Simply, is SB-600 good enough? If not, what am I missing?
Jun 02, 2009 at 12:10 AM
drpeters
Details
p.1 #8sb600 vs sb900
The 900 is like magic and the part I like best is the greater degree of head rotation, which is excellent for foofing.
Jun 02, 2009 at 01:58 AM
JHerr
Details
p.1 #9sb600 vs sb900
my sb-800 is great, except for one FATAL flaw. The one direction that I want to turn it the MOST is the one that I can't turn it at ALL. I definately need a sb-900, since I won't lug around a stupid bracket everywhere
Jun 02, 2009 at 02:46 AM
nikt
Details
p.1 #10sb600 vs sb900
I believe there have been some differences already stated as to what is different between the cameras.
No offence, but 'good enough?' is like "how long is a piece of string". If it's specs you're after , these are easy enough to come by.
However, here you go:
http://www.nikoncls.com/SB-ALL/sb689compare.html
Jun 02, 2009 at 03:37 AM
R. Francois
Details
p.1 #11sb600 vs sb900
the sb600 only zooms to 85mm the sb800 goes to 105mm and the sb900 up to 200mm. You wont get a diffusion dome with the sb600. you can always buy an omnibounce if you want to but that only adds up to the price No gel filter either. But i never use the standard gels... guess the rest has already been mentioned.
oh the Sb900 has a nice star wars sound too when a full flash is emitted. KA SHEEEW, leaving your subject toasted. How cool is that?
Jun 02, 2009 at 04:41 AM
JHerr
Details
p.1 #12sb600 vs sb900
That's...freaking..amazing..
im getting one
Jun 02, 2009 at 04:44 AM
Sam Bennett
Details
p.1 #13sb600 vs sb900
The SB-900 is a much, much more usable flash all the way around. If you have really basic needs the SB-600 will do, but it is so incredibly easy to configure the SB-900 for a variety of setups. I have one SB-900 and two SB-600s. The SB-600's are great to be used in a wireless setup in conjunction with the SB-900, but I wouldn't want to do without the SB-900.
As for complaints, the SB-900 can be a bit too much in some situations. It can't ratchet itself down lower than 1/128th, so if you're shooting fill in dark situations it's very easy for the flash to overpower your subject. I've found myself having to opt for the SB-600 in some cases where the SB-900 was just too much.
Jun 02, 2009 at 09:36 AM
Erik Moore
Details
p.1 #14sb600 vs sb900
For the brave:
http://www.planetneil.com/tangents/2008/07/17/i-just-strangled-my-nikon-sb-800-speedlight/
Jun 02, 2009 at 10:20 AM
Gregory.Rotter
Details
p.1 #15sb600 vs sb900
...Show more →
What do you mean, it cant ratchet down lower than 1/128th?? Cant you just set -1 or -2 ev for fill etc?? Or do you have to go manual?
Jun 03, 2009 at 02:58 AM
panos.v
Details
p.1 #16sb600 vs sb900
Gregory.Rotter wrote:
Sam Bennett wroteThe SB-900 is a much, much more usable flash all the way around. If you have really basic needs the SB-600 will do, but it is so incredibly easy to configure the SB-900 for a variety of setups. I have one SB-900 and two SB-600s. The SB-600's are great to be used in a wireless setup in conjunction with the SB-900, but I wouldn't want to do without the SB-900.
Whatever you do, the minimum output of the flash is 1/128 of max power. What happens is, iTTL meters the scene and then decides what power level to use, on a scale of 1/1 to 1/128. You can dial -2 FEC but if the correct exposure needs 1/128 then that -2 has nowhere to go to. Just like adding +1 FEC when the flash would fire at full power anyway.
However, given that the SB600 only goes down to 1/64 and given that the SB900 is about 1 stop more powerful than the SB900 then 1/64 on the 600 is the same as 1/128 on the 900. So I'm not really sure where the perceived advantage comes from. It is a much bigger issue when using the pop-up flash on some cameras. Even though the pop-up flash is weaker than a SB600, the pop-up can only dial down to 1/16 so the minimum output will be more than a SB600 dialed down to 1/64.
Remember, the actual power is always relative to the max power setting. So 1/32 on one flash is not the same as 1/32 on another.
If that makes sense.
Jun 03, 2009 at 04:04 AM
Avi B
Details
p.1 #17sb600 vs sb900
Panos, stop making sense
Jun 03, 2009 at 08:47 AM
panos.v
Details
p.1 #18sb600 vs sb900
I just mumble all the time!
Jun 03, 2009 at 08:51 AM
Sam Bennett
Details
p.1 #19sb600 vs sb900
The bottom line is that whether it's due to its power range or its guide number, the SB-600 will put out less power than the SB-900, and I've noticed this as being an advantage in some situations. This is with on-camera flash work, fwiw.
Jun 03, 2009 at 08:55 AM
codeninja
Details
p.1 #20sb600 vs sb900
Sam Bennett wrote:
panos.v wroteHowever, given that the SB600 only goes down to 1/64 and given that the SB900 is about 1 stop more powerful than the SB900 then 1/64 on the 600 is the same as 1/128 on the 900. So I'm not really sure where the perceived advantage comes from. It is a much bigger issue when using the pop-up flash on some cameras. Even though the pop-up flash is weaker than a SB600, the pop-up can only dial down to 1/16 so the minimum output will be more than a SB600 dialed down to 1/64.
Oh well, I set my mind on getting SB900...and, this...
Jun 03, 2009 at 09:29 AM
FM ForumsNikon ForumJoin Upload & Sell
