Sports Corner Rules
Sports Corner Resource
2 end
Archive 2009 · Getting the Most Out of Your FM Post- A Newbie Checklist
P Alesse
p.1 #1 · Getting the Most Out of Your FM Post- A Newbie Checklist
I have seen a lot newbies posting lately to FM and that's a good thing, but I'm also seeing a common thread of mistakes being made in posts. Hopefully this checklist will help...
Before posting your images, go through these items and adjust accordingly
1) Have I shot or converted my images to sRGB?
This is the most overlooked detail in posting. Color profiles are specific from medium to medium. For print, AdobeRGB is more appropriate, but web browsers don't often recognize the wider gamut of color information in an AdobeRGB color profile. This will result in color shifts, some more drastic than others, and a resulting image that looks flat in color.
2) Are my horizons straight?
A level horizon has been argued to death here on FM. I still maintain that the best horizons that look the best aesthetically, are not empirically straight... that is... set a bubble level to what should be straight and it could look off on screen. Since photographers really don't "take" photos, they "make" photos, it is the duty of the photographer to "make" the most pleasing image. This many require changing an in-camera horizon to one that simply looks better on screen. Using vertical lines as reference point is also not a steadfast rule. Those lines could be off as well and depending on the plane of the camera vs. the plane of the horizon which could be off skew, horizon lines won't do you any justice in setting the horizon straight. Use visual judgment... plain and simple.
3) Have I given too much information?
A simple caption is fine, but don't take offense to what I'm about to say and please understand this is just my opinion, but... I don't care what the score was, who won, the details of the game winning hit, the season that the player had, an inning by inning account of what lead up to the image, blah, blah, blah. This is a photo critique board, not a writing critique board. I want the image to speak for itself and it should. Always ask yourself whether your image tells the story as a standalone image. We don't have the benefit of having sat next to you during the entire game and really... why should we want that. A good image, is a good image. If you have to explain it, then it's not good enough as a standalone image. Even though this is just my opinion on the matter, I would still venture to guess that quite a few will skip past all the information about what happened in the game and just look at your images. We are visual people. I'll take it a step further and even say that for me, personally... I don't even care what gear you used or what your settings were. The image either works for me or it doesn't. However, in some cases, where I see issues, I might ask what your settings were and since you are in a period of exploring settings and outcome, it DOES make sense to post gear and setting for those that wish to give CC on that.
4) Have I embedded and numbered my images in post?
Links, even if simple, won't get as many responses. Some links require second and third clicks to get to what you want us to see. If people have to wait more than three seconds to see your images, you'll get less responses. Numbering your images in post is also critically important because it allows those wishing to offer CC a way to indentify your images. I can't tell you how many times I have skipped a post with mulitiple unnumbered images because of the time that would be required to physically count each image when giving CC. I may have wanted to give CC, but the time it would have taken scared me away.
5) Have I edited my post after people have responded?
This is a mistake that I have seen that I haven't seen addressed here. Here is the scenario... you post a set of images. You get a couple of responses stating that the images are underexposed. You go back, correct them, and then replace the original post with the new images. Now, the newer viewers to the post, see the first comments, go back to look at the images not realizing that you edited them, and they look fine to the new viewer. This leaves them confused. Don't confuse us. Unless there is something that is offensive, breaks forum rules, etc. Don't edit your original post. Don't even edit your original post and then post to the thread stating that you have edited the originals. Simply just post the changes in new photos that you can post later in the thread. Make it a chronological history so we can see where you started, where you are in the middle, and where you have wound up. Note... the new FM board code allows viewers to link to the first run of an edited post, but it requires a click (more time) and the link is hidden and not easily seen by all.
6) Have I done any post processing?
I'll be honest in saying that if a poster states that their image is straight out of the camera with no PP... I usually skip over the post. This is a presentation board. As well as presenting your images, you are presenting yourself. Whether true or not, someone that does no PP says to me that the time needed to present the best possible image to the audience is not worth it. People that are not photographers show their images out of the camera. Photographers don't. You're not taking photographs. You're making photographs. Everyone PP even if a little bit. Crop, color correction, USM are all part of the deal in making a good image, even better. Along the same lines, the "removing the watermark across the center of the image would require a different workflow" doesn't fly with me. I mean, c'mon. You need to present the best possible image for us to comment on and the attention to detail that you present speaks volumes about what kind of a person you are as a photographer.
7) Can I piss longer and harder than you?
Don't get into pissing matches with your audience. Come into the post with an open mind. You may be connected to an image emotionally and want to fight for it. But, if enough people think that its not as gripping as you think it is, it's not worth getting into a pissing match over. If you have an emotional attachment to all your images that is not shared by the general public, then lock yourself in your room, put all the prints on the floor and look at them every day without anyone else seeing them. Remember that you are making photos for an audience. The ones that have an emotional attachment for me simply NEVER get posted in a thread asking for CC. I know when an image moves me more that it would the average Joe. That's fine.
8) Have I posted an appropriate number of images?
Linking to a gallery of pages and pages of images doesn't fly and I have found that if you want CC on each individual image, the magic number of photos ranges around 4-8. Anymore than 8 usually gets you general comments. Any less than 4 often gets skipped over depending on the quality. 4-8 gives the viewer enough photographic information to weigh in with a response.
9) Am I implementing the suggestions being made into my newer posts?
There are some posters that I have stopped responding to simply because they keep doing the same things over and over again despite my CC. This conveys the message that they really don't want CC. A great way to get viewers to respond is to reference a past post via a link, such as... "in this post from 8/14/08 the majority suggested that I shoot tighter. I'd like to know if these images have improved in that critique." This shows that you are listening and implementing the ideas.
10) Did I die after my intial post?
I realize that our lives don't always permit us to respond to responders in a timely fashion, but don't post a thread with images for critique and then never revisit your thread. At the very least, come back, acknowledge that you have read the responses and offer your thanks.
11) Have I demonstrated good Isabellian etiquette?
Russ Isabella might be the record holder for the most responses to his posts. Why? Because he is just a nice guy. He takes the time to respond to others and others have returned the courtesy. Never, I mean never, have I seen him be rude, nasty, condescending, or brief in any one of his responses. He's a better man than me.... In turn, he receives the same courtesy and respect. You get back what you give on these forums and #11 should really be #1 on the list. Play nice and in time, you'll get responses and respect.
Edited on May 22, 2009 at 02:00 PM · View previous versions
May 22, 2009 at 01:52 PM
clarence3
p.1 #2 · Getting the Most Out of Your FM Post- A Newbie Checklist
Good stuff, Paul.
I'd add that EXIF should be included if possible, too. And a general description of what equipment and settings were used.
May 22, 2009 at 01:56 PM
Jon Uhler
p.1 #3 · Getting the Most Out of Your FM Post- A Newbie Checklist
Paul...you can't see me...but I am standing and applauding you my friend.
Michael H
p.1 #4 · Getting the Most Out of Your FM Post- A Newbie Checklist
May 22, 2009 at 03:44 PM
edemtbs
p.1 #5 · Getting the Most Out of Your FM Post- A Newbie Checklist
Thanks for the guidance and reminders.
How do I number the pictures if I upload them via FM "image upload"?
Ed
May 22, 2009 at 04:06 PM
P Alesse
p.1 #6 · Getting the Most Out of Your FM Post- A Newbie Checklist
Ed
You can't. But since, your are hopefully PP anyway, I'd number the actual JPG somewhere in the corner.
May 22, 2009 at 04:25 PM
Scott Sewell
p.1 #7 · Getting the Most Out of Your FM Post- A Newbie Checklist
Great post, Paul. Excellent points.
The only thing I would add is something about the size of images posted. I personally use the sportsshooter.com requirements of 600px on the longest side and have PS actions set up to resize for web use. I believe it shows a level of professional courtesy when images are a reasonable, consistent size and are easily viewable on the web.
May 22, 2009 at 04:50 PM
clarence3
p.1 #8 · Getting the Most Out of Your FM Post- A Newbie Checklist
Scott, hopefully that's 600px minimum?
May 22, 2009 at 05:07 PM
Scott Sewell
p.1 #9 · Getting the Most Out of Your FM Post- A Newbie Checklist
Nope. I meant what I typed.
I personally use 600px on the longest side, but anything withing 600-800px, IMO, is plenty for sharing on a forum like this. Afterall, the Sports Corner isn't the place for pixel peeping so I don't understand the need for images that are 3600px on the longest side. It works just fine for all the member galleries, contests and other posts on a site like sportsshooter.com. No reason it couldn't work here, too. Again, IMO, it gives the entire Sports Corner a consistent, professional look.
I don't want to get into a debate about something like this because it really doesn't matter to me if someone wants to post full-size images or little bitty images. But as it relates to the kinds of points Paul noted in his original post, when I open a thread that has huge images in it, I tend to hit the "back" button and move to another thread.
May 22, 2009 at 06:24 PM
clarence3
p.1 #10 · Getting the Most Out of Your FM Post- A Newbie Checklist
OK, no debate intended. I've been posting at 800px on the longest side, so I was unaware that 600px was the preferred maximum.
May 22, 2009 at 06:35 PM
BobnJake
p.1 #11 · Getting the Most Out of Your FM Post- A Newbie Checklist
Thanks Paul for taking the time to put this all down. It is very much appreciated.
I second, along with many others, all the nice words regarding Russ. He has taken the time, a lot more than once, to help me out.
Have a good holiday weekend
Bob
May 22, 2009 at 06:51 PM
P Alesse
p.1 #12 · Getting the Most Out of Your FM Post- A Newbie Checklist
Bob
Where in the hell have you been?
May 22, 2009 at 06:55 PM
Jeff Napier
p.1 #13 · Getting the Most Out of Your FM Post- A Newbie Checklist
This was a good idea Paul, thanks I only hope that I dont forget one. Please let me know if I do. I value yours and the others CC here on FM I have learned alot.
Also +1 on Russ his awsome feedback and contributions to the forum.
While I'm at it Scott thank you too.
pacdzyne
May 22, 2009 at 08:28 PM
kiz5
p.1 #14 · Getting the Most Out of Your FM Post- A Newbie Checklist
Great advice for those coming aboard.
May 22, 2009 at 09:56 PM
tinamarie52
p.1 #15 · Getting the Most Out of Your FM Post- A Newbie Checklist
From someone new to this site, many thanks for the timely introduction to 'posting etiquette'.
May 22, 2009 at 10:30 PM
DannWunderlich
p.1 #16 · Getting the Most Out of Your FM Post- A Newbie Checklist
Thanks Paul, this was a great post.
May 22, 2009 at 10:41 PM
cm0rris0n
p.1 #17 · Getting the Most Out of Your FM Post- A Newbie Checklist
This should be "stickied".
May 22, 2009 at 11:40 PM
RobertCB
p.1 #18 · Getting the Most Out of Your FM Post- A Newbie Checklist
Thanks for starting this thread. I am new to all this and have tripped up myself by doing a few of thing you listed. Now I have a blue print to follow on my future posts that will help me in my presentation and interaction with the board. Thanks again.
May 22, 2009 at 11:45 PM
dj dunzie
p.1 #19 · Getting the Most Out of Your FM Post- A Newbie Checklist
* More applause here *
I'm just wondering which thread made you wanna go and put this service advisory forward to everyone!
Well written, well taken, and hopefully well-adhered-to by future posters! Let's sticky this sucker...
Oh, and "Isabellian". I'm gonna coin that term! Every day we should all strive to be more and more like Russ I say!
May 23, 2009 at 03:55 AM
PShizzy
p.1 #20 · Getting the Most Out of Your FM Post- A Newbie Checklist
I like the post, but I have to admit, I'm not in agreement with #6. Anyone with the right Photoshop experience can make their image look good. If you present your work in that light, then we're looking at your work as a photographer who knows photoshop. But if you present the photo, we can see the foundation upon which you stand, the way you really shoot and what we're really looking at so we can give you valid advice.
Let's say you color correct your images very well, fixed the exposure, and straighten all your horizons. If we don't know the degree to which you do that, how can we know you're a good shooter. We just know you can polish a passable image. But if you can nail it in camera, and show us that, now we know you understand photography, and perhaps Photoshop can be used to enhance that work.
It's the same reason I like to know what women look like without their makeup...
Now, if someone said "port review", thats a different matter. That's an end game. That's where you need to put it all together.
Max
May 23, 2009 at 04:05 AM
rbranan
p.1 #21 · Getting the Most Out of Your FM Post- A Newbie Checklist
So Max, do the women like seeing you with or without your makeup??
I say photoshop those puppies. never on the EXIF-- images stand on their own. who looks at EXIF stuff anyway??
May 23, 2009 at 04:43 AM
PShizzy
p.1 #22 · Getting the Most Out of Your FM Post- A Newbie Checklist
bob, for the sake of critique, don't we want to know what you can do with the camera, not with photoshop?
But for a client? ya, do what you have to within the construct of the assignment. I'm simply commenting on when someone says "how can I improve my shots". If they're photoshopped well, you may not be able to see the fundamental flaws in someones technique.
Max
May 23, 2009 at 05:20 AM
rbranan
p.1 #23 · Getting the Most Out of Your FM Post- A Newbie Checklist
i see you side stepped the make-up question...
on the photoshop issue, it seems to me the final product is typically a photoshop'd image (or whatever software you choose to process an image). if you submit to an online, paper, or client it is likely you will be sending an 'enhanced' image. so, i rather see folks here learn how to do the whole cycle. you are totally correct that a great shooter will get a killer shot straight out of the camera. but if you look at the work of some of the greatest shooters, you are likely seeing a image that has been touched up. like you, i know some of the shooters that are big names and worked side-by-side in the press rooms with them---most have their own 'tricks' to get an image to standout. digital techs make BIG bucks in NYC working for top photographers for a reason.
the only thing that kinda ticks me off is the over-cropping some folks do when they post. it is much harder getting a image with a meaningful background along with a great primary subject. many poster's seem to think a nice tight crop of a ball on a bat is a great shot....
May 23, 2009 at 05:45 AM
Bryan Crowe
p.1 #24 · Getting the Most Out of Your FM Post- A Newbie Checklist
Well put there Paulie !
May 23, 2009 at 08:41 AM
m00g
p.1 #25 · Getting the Most Out of Your FM Post- A Newbie Checklist
Thanks for laying this down. It'll help me learn from all the long-standing 'togs here.
Cheers!
May 23, 2009 at 09:03 AM
2 end
