Archive 2004 · Anyone have Pelican Case photos?
teriba
p.1 #1 · Anyone have Pelican Case photos?
I want to see how you organized your stuff before I start ripping out my foam. I got a Pelican 1500 and here is what I'm putting into it:
300D + grip
70-200 f/2.8 IS
50 f/1.4
17-40 f/4
1.4x TC
X-Drive II w/ charger
6 batteries w/ charger
2 CF cards
Thanks.
Feb 27, 2004 at 07:14 PM
Scotty G
p.1 #2 · Anyone have Pelican Case photos?
Pelican makes an insert for the 1500 case that is specially designed for photography. Pelican product number 1505 for the 1500 case. You can see it here
http://www.pelican.com/cases/cases2.html
This looks like the perfect setup as you can re-arrange it over and over.
Got this case (or the 1600) in mind for a future purchase. Would be interested to hear how it works out for you.
Good Luck
Scotty
Feb 27, 2004 at 08:43 PM
rdonson
p.1 #3 · Anyone have Pelican Case photos?
Not sure I can be of help. I have a Pelican 1610 with padded dividers. It allows me to rearrange whenever I need to.
1610
Edited by rdonson on Feb 28, 2004 at 02:51 AM GMT
Feb 27, 2004 at 09:50 PM
teriba
p.1 #4 · Anyone have Pelican Case photos?
Yeah, I'm going to try the foam first because it came with it. If it doesn't turn out that great I'll get the dividers. What do you think of the "Photographers Organizer Lid" thing?
teriba
p.1 #5 · Anyone have Pelican Case photos?
Also, my gear is not going to change much if that matters either way. This is going to be my "race box" and only has my gear I use at races. I shoot mostly rowing so I'm out in a little powerboat most of the day so my stuff gets wet sometimes.
Feb 27, 2004 at 09:52 PM
teriba
p.1 #6 · Anyone have Pelican Case photos?
I found this image, pretty close gear to what I have. I don't know if I want to mount a lens on my body though.
Feb 27, 2004 at 09:54 PM
rdonson
p.1 #7 · Anyone have Pelican Case photos?
The lid organizer looks pretty cool. Here it is at B&H. It doesn't seem unreasonably priced. I'm going to think about this. I may end up buying one.
L Weathers
p.1 #8 · Anyone have Pelican Case photos?
I recently purchased a LowePro Omni Pro Attache w/Extreme hard case,
ref B & H # LOOPEB. It is a nice shoulder bag in a hard case.
I'll never go back to the pick & pluck foam. The foam can't be rearranged and leaves debris which might jam-up lenses & bodies.
Feb 27, 2004 at 10:01 PM
Chris Dodkin
p.1 #9 · Anyone have Pelican Case photos?
Here's my Pelican case set-up:
The gaps are for 2nd body, 550EX flash and 17-35 F2.8L
Great hard cases!!
Chris.
Feb 27, 2004 at 10:21 PM
teriba
p.1 #10 · Anyone have Pelican Case photos?
What size is that?
Feb 27, 2004 at 10:28 PM
Chris Dodkin
p.1 #11 · Anyone have Pelican Case photos?
1600 If my memory serves me well.
You can also get this case as the 1610, which has wheels and a pull out luggage handle.
Chris.
Feb 27, 2004 at 11:10 PM
chez
p.1 #12 · Anyone have Pelican Case photos?
Has anyone experienced problems with the "pluckable" foam inserts over the years. I've read a post on another forum where some of the foam started to deteriorate over time, causing fine pieces to make their way into the cameras and lenses.
Feb 28, 2004 at 12:51 AM
brianjonesfoto
p.1 #13 · Anyone have Pelican Case photos?
sometihng to consider with the lid inserts. They replace to top padding. I have an insert on the lid of my 1650 and sometimes I wish I had a little extra padding in there as it's my lighting case.
Feb 28, 2004 at 01:07 AM
teriba
p.1 #14 · Anyone have Pelican Case photos?
Yeah, I'm a little worried about that. I'm going to go without the organizer for now.
Feb 28, 2004 at 06:34 AM
Jim Kenny
p.1 #15 · Anyone have Pelican Case photos?
Hey, I have had a 1500 Pelican Case for over 15 years (heavy use working as River Guide) never had use for the pick & pluck foam so I just saved it in the garage. Six months ago I broke out the foam for camera use. Foam still is great shape, no dry rot or deteriorating. Lid space was an issue for me also. Ended up using hard plastic VCR case, Velcro to the lid. That is where I stash little stuff, like battery charger cable, lens covers, mono pod wrench, .....
I got the 70-200 lens AFTER I plucked the foam now the fit is not as good - I instead of having the body and lens (I keep the 70-200 on the body) lined up fFROM "handle to hing" I would rather line it up ALONG the handle or hing. Oh well, I do not have the BG-ED3 grip so I cant speak of the fit with that attached to the body in the case.
Sorry for using links but -
This link shows the layout (hole is from camera used to make photo - also the 24-70 lens - you can see the green lens bag)
http://jim5293.fotopic.net/p3044572.html
This link shows the velcro attaching the VCR cases
http://jim5293.fotopic.net/p3044549.html
This link shows the stash inside the VCR cases
http://jim5293.fotopic.net/p3044561.html
The VCR case are thick enought to keep stuff in the pick and pluck from flopping around - You will have quite a load in the case if you can get it all in. But it will be secure inside the case - heavy but secure
Hope it helps
Jim
Feb 28, 2004 at 08:15 PM
teriba
p.1 #16 · Anyone have Pelican Case photos?
Great! Thank you Jim! Now I have some good ideas for mine. I'll combine the power of all of your minds!!
Feb 28, 2004 at 08:32 PM
Josh Robinson
p.1 #17 · Anyone have Pelican Case photos?
Here is what the inside of my Peli 1550 looks like: (Sorry for the cheesey fade off into white)
Feb 29, 2004 at 01:55 AM
bgdenys
p.1 #18 · Anyone have Pelican Case photos?
Lowepro Omni Trekker in Pelican 1550:
Bart
Feb 29, 2004 at 03:54 AM
Chris Dodkin
p.1 #19 · Anyone have Pelican Case photos?
No issues in two years of use.
Chris.
Mar 01, 2004 at 11:24 PM
randyb
p.1 #20 · Anyone have Pelican Case photos?
FWIW, I got the 1620 with photo inserts for air shipping my stuff or carrying all of it, and the 1520 with the photo insert for carry-on travel. Both have plenty of room. With the 1620, I can carry the 300/4, 70-200, 50-500, my hi-ti printer & cords paper, and all my smaller lenses, and flashes. The 1520 will hold the 300/4, 70-200, my Zenitar 16/2.8, 50/1.8, and the 28-75/2.8 and flash. Can't go wrong with either. Pelican makes a removeable carry bag for the 1520 also. Haven't used it though.
randy
Mar 02, 2004 at 01:45 AM
andyturk
p.1 #21 · Anyone have Pelican Case photos?
Bart,
The 1D is a little over 6" tall, but LowePro says the case you're using is only 5.25" high inside. How do you get the 1D to fit in there?
Mar 02, 2004 at 04:59 AM
teriba
p.1 #22 · Anyone have Pelican Case photos?
Final product!
Mar 02, 2004 at 05:15 AM
SteveXs2
p.1 #23 · Anyone have Pelican Case photos?
For those of us that pack light:
The gap in the lower left is for my digital camera. I have much more in it now, like a small felt pen, cokin diffuser, cokin filter holder and some other junk. It's the 1200 case and it fits nicely in my backpack for skiing and stuff.
By the way, it's a Rebel Ti with EF 28-105mm f/3.5-4.5 II USM with the lens hood in there.
Mar 02, 2004 at 06:10 AM
christo™
p.1 #24 · Anyone have Pelican Case photos?
Hi, Teriba:
You've already bought a Pelican, and they are great cases, but I've found better prices on equivalent cases in the Seahorse line, as well as a lot of other neat cases and ideas. I own two Pelicans and a Seahorse. I found the Seahorse through eBay over two years ago, and ended up exchanging e-mails with the company owner, Michael B. He's a great guy, a plastics engineer by trade who ended up founding his own case company, and he really knows his stuff.
See:
http://www.fuertecases.com/
The SE line is a little "lighter duty" than the Pelicans, though my case has seen pretty bad abuse in the last 2.5 years, and not a single part has broken. I specifically wanted the lighter case. The SX line is heavier duty, though short of white water rafting and parachuting, I don't know what you'd need the extra strength for.
I have no affiliation with this outfit other than being a happy customer, but I highly recommend that anyone looking into hard cases check them out. Their cases are great, cost less than the Pelicans, and you can get spare parts like O rings and foam insert material inexpensively right off the web site. Even if, like me, you made the mistake of buying Pelican cases before knowing about Seahorse, the Pelicans can use the foam from Fuerte just fine (I buy the largest inserts for all cases, and cut them down with a bread knife).
As far as the foam inserts, I usually end up changing around my foam often enough that I've never had any wear out, and I keep a couple different inserts around for each case so I can load them differently depending on what I'm going to need along. After finding Fuerte Cases, I ordered a case of foam inserts of the biggest size, and have been using them up replacing the inserts in my Seahorse and Pelican cases. I called Michael before making this post, and he says that UV exposure is the major problem in foam deterioration, but obviously that is not much of an issue unless you are a moron: the case isn't doing you any good when it is lying open exposed to the sun! Even a lazy bum like me can manage to flip the lid closed after swapping lenses. According to Michael, you should easily expect 3 years out of the foam, and 5 wouldn't be unreasonable unless you like to leave your case open in the sun.
I bought all pick-a-part foam inserts, but I usually use a serrated paring knife to cut out holes for my equipment. As far as getting bits of foam all over the equipment, I find a much bigger problem with the mess right after cutting the foam than down the road with deterioration of the foam. After making the foam mess mistake once, I thoroughly clean off the foam with my air compressor after cutting and before loading it with equipment. I haven't had problems with the foam getting into my equipment, but it sure gets all over the lenses if not cleaned up ahead of time, and static electricity makes sure it sticks.
When I told him about this post, Michael mentioned that he has one customer that covers his foam inserts with a silky material like coat lining fabric and pins it underneath the insert. He also mentioned that Fuerte Cases now has foam padded liner inserts similar to what are in a camera bag available for their hard cases.
Well, this is getting too long, but there are two points I'd like to make come through: First, if you have any questions about hard cases, Fuerte Cases is the best source I've found for cases and knowledge (call Michael!). Second, if you really plan on getting use out of your case, buy extra foam inserts right off the bat, and make yourself inserts for a couple different loadings.
Mar 02, 2004 at 06:31 PM
bgdenys
p.1 #25 · Anyone have Pelican Case photos?
andyturk wrote:
Bart,
Actually pretty easy. It is snug but still very acceptable. Remember that the Omni Trekker is a soft case. Once put in the 1550 there is plenty of room for it.
Bart
Mar 03, 2004 at 12:04 AM
