Archive 2009 · [fixed] Rokkor 58mm f1.2 hazy.
nismoxr34
p.1 #1 · [fixed] Rokkor 58mm f1.2 hazy.
I was wondering if the issue would be due to the slight damage on the rear element of the lens. When I dial up to f/2 the issue is mostly resolved. Or is it the fact that I am not focusing correctly or exposing due to the large aperture?
Here is an example of the issue.
f/1.2
f/2
never mind, figured out the reason.
Edited on Mar 31, 2009 at 12:03 PM · View previous versions
Mar 30, 2009 at 10:16 PM
alexandre
p.1 #2 · [fixed] Rokkor 58mm f1.2 hazy.
what was it?
Mar 31, 2009 at 07:45 AM
ovredal73
p.1 #3 · [fixed] Rokkor 58mm f1.2 hazy.
Please share your findings, even if they are embarrassing
Mar 31, 2009 at 09:24 AM
nismoxr34
p.1 #4 · [fixed] Rokkor 58mm f1.2 hazy.
I recently bought a rokkor 58mm f1.2 on ebay for 260, and the guy said it was dreamy wide open. I thought, this couldn't be an issue with the lens. I knew the rear lens would have slight marks on it but also knew it should effect image quality.
I was looking at the glass and though it was a little dirty and took it apart to clean. Put it back together and it was the same. I was thinking, maybe I should flip the rear lens and see what happens, and Voila! fixed.
Here is a sample wide open now, I am currently trying to get an EE-S screen for my 5d to fix MY focusing issues. But this is what I got so far. A LOT better!
Mar 31, 2009 at 12:02 PM
ovredal73
p.1 #5 · [fixed] Rokkor 58mm f1.2 hazy.
Cool! Nice shot too. You will love the Ee-S
Mar 31, 2009 at 03:57 PM
alexandre
p.1 #6 · [fixed] Rokkor 58mm f1.2 hazy.
That's what I thought - actually I thought some elemet misalignment after cleaning. Your case was an extreme misalignment glad you fixed it. Congrats!
Mar 31, 2009 at 06:01 PM
wkhc168
p.1 #7 · [fixed] Rokkor 58mm f1.2 hazy.
How do you remove the rear element? It seems very securely mounted.
Apr 01, 2009 at 02:40 PM
ovredal73
p.1 #8 · [fixed] Rokkor 58mm f1.2 hazy.
you unscrew the the rear lens retainer ring. Probably have to use some tool, but has been done on all my rokkors - 4 or 5 by now.
André
Apr 01, 2009 at 04:09 PM
