BrianO Offline Dedicated FM Upload & Sell: On
p.1 #9 · mini softbox for 580EX? | |
yauyi wrote: Few months ago I saw someone using what appear to be a mini softbox mounted on his 580EX, I believe he use a flash bracket for the 580EX.
Probably not the LumiQuest LQ-109, which is designed for use on barebulb flash guns. Since you said it was on a 580EX, I'd guess it's the LQ-107, or the larger LQ-119.
They have a denser center section on a more translucent outer section to even out hot spots from being so close to the flash tube.
Not a big difference, from what I've seen, over the plain flash; but there is some difference. The 107 increases the size of the light source by about double, and the 119 by about 3 or 4 times, which if you're up close can give a noticable softening of shadow lines.
Is one of these what you saw?
