2 3 4 end
Archive 2009 · BW Films
joekraft
p.1 #1 · BW Films
First, is Alt. the correct ('best') forum for film-related questions now, or should this be general gear talk?
The main question: How does Kodak TMAX compare to Ilford HP5 Plus?
Thanks!
Feb 28, 2009 at 06:00 AM
dirb9
p.1 #2 · BW Films
Eh, I think either forum is fine.
As for your film question, TMAX (400, I assume) compares more closely to Delta 400 from the Ilford line. TMAX/Delta are T grained films, which means that they have finer grain than a comparable ISO film that is traditional (aka cubical) grained. The current generation of 400 Tmax (400 TMY-2) is extremely fine grained for a 400 film, if not the finest grained 400 speed film out there period. I find that one trade off is that Tmax has slightly less latitude than HP5, although I personally like the tonalitly of Tmax better than HP5. I have also found that HP5 is ever so slightly more contrasty than Tmax. I personally think that HP5 looks less realistic compared to Tmax, but with b&w films, that depends as much on your technique and how the film is developed as much as the film itself.
Feb 28, 2009 at 08:52 AM
Tariq Gibran
p.1 #3 · BW Films
Agree with the above poster. My experience is that traditional B&W films can often have more roll off in the highlights and are a bit more "malleable" with regard to exposure/processing. The newer technology films offer finer grain but at the expense of the above. That's a generalization to some extent but seems to hold true in many cases. I personally prefer the tonality and micro contrast I can get out of something like Tri-X 320 to TMAX 400 when using partial stand development processing techniques. Some people love the tonality of TMAX so it's all very subjective. Best thing to do would be to shoot, shoot, shoot and experiment with different developers/techniques to see what you like.
Feb 28, 2009 at 01:10 PM
mawz
p.1 #4 · BW Films
I'd agree overall with the above. With the caveat that I loathe the tonality of TMax and Delta in general, their very linear tone curves result in a very 'digital' look.
HP5+ is far more flexible with regards to development and exposure than any TMax (you can use just about any developer with decent results and HP5+ is insanely pushable, I typically shoot it at EI 800 or EI 3200).
Feb 28, 2009 at 01:27 PM
Tariq Gibran
p.1 #5 · BW Films
I was trying to be 'diplomatic'. My personal opinion is similar.
Feb 28, 2009 at 01:43 PM
brucemuir
p.1 #6 · BW Films
The new t-max 400 is much better in regard to tonality and flexibility in processing than the older Tmax 400.
Feb 28, 2009 at 01:47 PM
joekraft
p.1 #7 · BW Films
Thank very much. I'm just getting into film, and it is pretty exciting. I'm not sure if home-development is in the cards yet though - e.g. not sure how much I can take advantage of the better flexibility of the HP5. I do like it though - got 3 rolls with the camera, and just ordered 5 more. I would like to try the TMAX after that though, just to see how it turns out.
Feb 28, 2009 at 02:18 PM
Daniel Buck
p.1 #8 · BW Films
are you shooting 120? or 35mm? If you are shooting 120, I would recommend Tri-x 320, it's a great film It's not made in 35mm though (at least I don't think it is). It's very easy to develop too, it's pretty forgiving (at least it is in HC-110) and seems to hold alot of shadow and highlight detail. Though, I've never done any real comparisons with other films directly.
Feb 28, 2009 at 04:39 PM
Tariq Gibran
p.1 #9 · BW Films
My favorite as well when shooting 120.
Feb 28, 2009 at 04:47 PM
anthonygh
p.1 #10 · BW Films
DIY film processing is so cheap and easy it's almost criminal not to do your own......
Feb 28, 2009 at 05:03 PM
brucemuir
p.1 #11 · BW Films
especially if you ever get back scratched negs.
Feb 28, 2009 at 05:10 PM
joekraft
p.1 #12 · BW Films
Shooting 120...I'll put tri-x on the list too - thanks.
Feb 28, 2009 at 05:30 PM
joekraft
p.1 #13 · BW Films
That's what I hear, but I'm not too big to admit I'm way intimidated. I'm sure I've seen a link before, and ignored it figuring it wouldn't apply to me, but, is there a good resource for getting started - what the minimal requirements are? I shoot both color and B&W. If it is something I could do in an hour or two in the garage, I'm game (all my negatives will be scanned - no making prints from them), but I don't have any room for any kind of wet darkroom.
Feb 28, 2009 at 05:33 PM
Daniel Buck
p.1 #14 · BW Films
Here's something that my uncle told me, and it's ringing true. Pick a film & developer and stay with it for a while. That way you really get to learn how it works, and how it's affected by changes. Switching films all the time is a good way to spin your wheels. But if you know your film real good, you'll know when it's time to grab a different film if your situation demands more than what your current film can do
So far however, the only thing that I've not been satisfied with when using Tri-x 320 is the fact that Kodak no longer sell it in 50 sheet boxes for 8x10 (only 10 sheets per box now!!! That's annoying!). And now that I'm getting into flash shooting, the 320 speed is just a little to fast for me to keep my apertures more open where I want them, so I've been trying some slower films, 25 and 100 speed Adox and Arista EDU.
As for developing, B&W is easy as pie. You really only need two chemicals, a developer, and a fixer. With alot of rapid fixers, you don't need a stop bath (other than just water!). And I also put in a few drops of LFN wetting agent into my final rinse. You can surely do it in a few hours (much less!), unless you have alot of rolls. (not including drying time) I don't even have a dark room, I just use a changing tent and daylight tanks.
Feb 28, 2009 at 05:46 PM
anthonygh
p.1 #15 · BW Films
For a stop bath I use white vinegar! I have a windowless laundry room and load films into the tank in there....at night so no light anywhere. Start to finish is about 30 minutes ( not counting drying time)...I hang the negs from the shower curtain rail overnight. All the kit can be obtained from ebay for about £30.
Film dev times available via Google normally. For a novice I'd suggest a film like FP4plus.. It will tolerate a bit of over / under development...scans beautifully...and can be pushed or pulled if required ( but not that necessary if scanning..infact; pushing probably not that advisable anymore...pulling brings in a better tonal range I think).
I've never bothered with colour.....more complicated, and I stick to digital capture for colour anyway.
Feb 28, 2009 at 09:49 PM
mh2000
p.1 #16 · BW Films
Ok then... *I* think TMY blows HP5+ out of the water on all counts!
The current TMY-II is the finest grained 400 speed b&w film ever and has greater latitude than anything else I have ever used.
HP5+ is a pleasing old school emulsion... but if you are going that route *I* think TX is Godhead... so take my opinions for what they are worth.
Honestly, I think TMX and TMY are the best b&w films ever... (once you learn to develop them correctly I guess, but I never had the problems that others on line seem to have had).
Feb 28, 2009 at 10:01 PM
mh2000
p.1 #17 · BW Films
PS I have been stand developing my TMX and TMY in Rodinal 1:100 and taking a full 1-stop push... very happy with the results... very sharp and classic tonality.
Feb 28, 2009 at 10:03 PM
Tariq Gibran
p.1 #18 · BW Films
I stand develop in Rodinal 1:64 or HC110 as well, depending on what I am processing. Stand development was the only way I was ever able to exhaust the developer in the highlights with Tmax and get any sort of meaty, micro contrast in the mid to upper mid-tones yet it still always seems compressed to what the old school emulsions are capable of. I have not tried Tmax in a number of years so perhaps it has improved.
Mar 01, 2009 at 01:12 AM
mh2000
p.1 #19 · BW Films
I never understood why Tmax films have always been the most controversial b&w emulsions ever... back when I bought my first roll it was a brand new film that I didn't know anything about, didn't even know what tabular grain was... threw the roll in D76 and was really wowed! by it... much better grain and tonality than I ever got out of Plus-X... but whenever I start raving about it over the years at least half the people I talk to tell me about how horrible it is for them... the other half seems to feel like I do that it is the best...
The good thing about b&w film is that there seem to be people getting truly excellent results from all the available emulsions... best to just find one that works for you without much effort and just hone your process around that one.
Mar 01, 2009 at 02:24 AM
Marcel VanEerd
p.1 #20 · BW Films
I haven't processed film in several years, but when I did, Tmax 100 & 400 were my favourite films. To bring out more tonality and grain (yes, I like grain) I used Agfa Rodinal developer. A killer combination imho.
Mar 01, 2009 at 02:33 AM
mh2000
p.1 #21 · BW Films
I do like the clarity you get from Rodinal... but I love that it lasts *forever*
My bottle was first opened 12 years ago and still works perfectly... try that with anything else!
Mar 01, 2009 at 02:37 AM
mawz
p.1 #22 · BW Films
TMax is very picky about exposure and development, exhausts fixer very quickly and has an extremely linear tonal response. That's pretty much a prescription on how to annoy the average B&W shooter. For the most part, when I find somebody who likes TMax, they tend to be either Zonies of some sort, small grain uber alles types or folks who manipulate heavily at the printing stage.
I've never gotten decent results out of TMX or TMY, even the new stuff. But a lot of that is that TMX and TMY are designed for different applications. If you want a classic B&W look, HP5 or Tri-X are far better choices (especially if you like the feel grain adds to an image, which I do). TMX and TMY are too close to digital in look for me (because of the linear response curve), if I want that look I'll just shoot digital instead.
Mar 01, 2009 at 02:00 PM
Tariq Gibran
p.1 #23 · BW Films
I agree completely. I usually shoot Tmax 400 and end up manipulating the hell out of it, both in processing and print. Whenever I have shot it 'straight', I find it must be exposed as critically as shooting chrome (except, of course, you expose for the shadows, process for the highlights). All the below shot with Tmax 400. It is a film I guess I love to hate but strangely, I have used it often.
Mar 01, 2009 at 02:52 PM
mh2000
p.1 #24 · BW Films
hmmm... about being picky about exposure, the Tmax is the only silver based film that the manufacturer states that you can take a one stop push with no change in developing... so I find it about the most forgiving of all the silver based films. I don't find it exhausts fixer, but often people think that all the pink must come out during fixing when in reality it clears out during washing.
Mar 01, 2009 at 10:44 PM
Tariq Gibran
p.1 #25 · BW Films
It used to take at least twice as long to fix as conventional film based on the 'manufacturers suggestions'. To nail the film, exposure is extremely critical, much more so than conventional films such as Tri-X. 'Manufacturer suggestions', not just Kodak's by the way, regarding true B&W film speed and processing times are, shall we say, about as reliable as used Yugo's. Extremely rough starting points at best.
Mar 01, 2009 at 11:02 PM
2 3 4 end
