Archive 2009 · Canon 5DII + Zenitar fisheye
horstenj
p.1 #1 · Canon 5DII + Zenitar fisheye
There have been some reports in the past that the Zenitar 16mm fisheye could block the mirror of the 5D as it protrudes a bit more into the body then other lenses. As I already had a Zenitar and just got my 5DII, I was anxious to know whether that would be the case with a 5DII. I'm sure there are others out there with the same question.
I hesitated long, said several prayers, counted on my warranty and bit the bullet.....
It worked. No problem. Great news.
Joost
PS also my Peleng 8mm works fine, but I never heard any problems there.
Feb 15, 2009 at 01:09 PM
ovredal73
p.1 #2 · Canon 5DII + Zenitar fisheye
Good to know
Feb 15, 2009 at 02:36 PM
victorXT
p.1 #3 · Canon 5DII + Zenitar fisheye
The reported problems when using the Peleng are with the filter holder mounted on the back. This can hit the 5D's mirror. Without the holder there should not be a problem.
Feb 15, 2009 at 03:06 PM
Jonas B
p.1 #4 · Canon 5DII + Zenitar fisheye
But the filter holder with the clear filter in it is supposed to be there as a part of the design. What happens with the IQ if removed. I expect the focusing ring would need a recalibration but is there anything else happening?
Feb 15, 2009 at 03:21 PM
victorXT
p.1 #5 · Canon 5DII + Zenitar fisheye
If the filter is just a filter, then there should not be any problems. If it is an actual lens element, then it would be hard to find filters for it and omitting it would indeed require adjusting the focus mechanism. But I think this will not be the case.
Feb 15, 2009 at 03:30 PM
Jonas B
p.1 #6 · Canon 5DII + Zenitar fisheye
The filter is just a filter. I just seem to remember people having reported the need of adjusting the distance scale. Well, my guess is there should be no problems.
horstenj; did you remove the rear end filter?
Feb 15, 2009 at 03:51 PM
horstenj
p.1 #7 · Canon 5DII + Zenitar fisheye
No, I left the clear filter in place. As I understand, this clear plate is essential for the optical design. I have not tried without it. The Peleng came with a set of color filters to could replace this clear filter (of no use in the digital age).
here are some test pics (no technical or creative quality claimed ). Also posted on the Canon forum.
Zenitar:
http://horstenj.zenfolio.com/img/v4/p823454159-4.jpg
Peleng (motion blurred as the missus got upset that some grey hairs may be visible from this angle :
http://horstenj.zenfolio.com/img/v4/p623788716-4.jpg
Note that the Peleng image circle is slightly clipped and slightly asymmetric. I do not expect this to be problem as the rim as considerable chromatic abberation anyhow.
Joost
Feb 16, 2009 at 01:38 AM
ISO1600
p.1 #8 · Canon 5DII + Zenitar fisheye
i would never dream of putting a shitty zenitar or peleng on a 5DII, not even as a joke.
Feb 16, 2009 at 02:05 AM
Daniel Buck
p.1 #9 · Canon 5DII + Zenitar fisheye
not all of photography has to be sharp and taken with the worlds best lens. I've taken large format shots with lenses just a step or two higher than the bottom of a coke bottle
Feb 16, 2009 at 03:14 AM
patrickphoto
p.1 #10 · Canon 5DII + Zenitar fisheye
I love my cheap zenitar, and for a 10 buck fisheye, it works wonders at f11 at night!
Feb 16, 2009 at 03:54 AM
thrice
p.1 #11 · Canon 5DII + Zenitar fisheye
I agree, typically people don't use fisheye that often as it is only particularly suited to certain applications. Spending a lot on the canon fisheye (or worse yet 16mm f-distagon) when you are comfortable with a manual lens is almost foolish. The Zenitar is also surprisingly good at f11.
Feb 16, 2009 at 05:41 AM
horstenj
p.1 #12 · Canon 5DII + Zenitar fisheye
Same holds for me. I use the Zenitar and Peleng only very occasionally. Mainly for pano and QTVR experiments and an occasional fun shot. I got them 2nd hand from ebay and I find them both great value for the relatively little money I paid.
Would I need a fisheye on a more regular basis, I'd definitely go for a more modern lens though, if it would be only for the automatic diaphragm.
Joost
Feb 16, 2009 at 07:23 AM
Mike Ganz
p.1 #13 · Canon 5DII + Zenitar fisheye
Joost
Does your Zenitar have an EOS mount, or are you using an adapted lens? Just curious since a while back I had an EOS-mount Peleng for my 30D and had some focusing issues, which I had attributed to the mount...
Feb 16, 2009 at 07:02 PM
horstenj
p.1 #14 · Canon 5DII + Zenitar fisheye
No, it is an M42 Zenitar with an EOS adapter. I've not tested it extensively yet on my 5DII but I had no focus problems on the 20D.
Joost
Feb 17, 2009 at 01:58 AM
TWoK
p.1 #15 · Canon 5DII + Zenitar fisheye
Where do you find Zenitars for $11?
Feb 17, 2009 at 06:13 AM
horstenj
p.1 #16 · Canon 5DII + Zenitar fisheye
I paid 100-120 euro for mine (can't recall the exact amount).
Joost
Feb 17, 2009 at 08:21 AM
TWoK
p.1 #17 · Canon 5DII + Zenitar fisheye
I had one given to me but it hit the mirror on my 5D, so I gave it back to my friend.
Feb 17, 2009 at 08:26 AM
Anden
p.1 #18 · Canon 5DII + Zenitar fisheye
I have no problem with the Zenitar 16/2.8 and 5DII either. I have the filter installed in the back.
A
Nov 11, 2009 at 07:25 AM
Jonas B
p.1 #19 · Canon 5DII + Zenitar fisheye
+1.
Not even dreaming about putting a Zenitar on the 5DMkII seems to be a way to limit oneself. The Zenitar isn't stellar but it is certainly good enough for a lot of funny applications.
Nov 11, 2009 at 11:07 AM
Anden
p.1 #20 · Canon 5DII + Zenitar fisheye
It is actually fun to use. I have great lenses when I need it but this will do for movies and such when I do need a fisheye.
Nov 11, 2009 at 11:16 AM
