Archive 2009 · 40d upgrade
Wildlifepics
[X]
p.1 #1 · 40d upgrade
Most of my photography is BIF and action .I use the 40d and Canon 400 5.6 I would like to have better and more reliable autofocus . Would the mark 2 be a big upgrade . Cant swing Mark 3 right now so Im I think Ill be looking for Mark 2 . What about 1.6 crop versus 1.3 . Will that be a big issue ?
Jan 06, 2009 at 05:44 PM
Daan B
p.1 #2 · 40d upgrade
I am curious... in what way is the 40D's AF unreliable in AI Servo?
I think the general consencus is that the 1D2's AF is one of the best out there, even when compared to the mkIII series.
Jan 06, 2009 at 05:50 PM
Gary Petersen
p.1 #3 · 40d upgrade
I know the Mk III's autofocus is light years beyond what my 20D would do. I imagine the Mk II's to be similar.
Jan 06, 2009 at 05:54 PM
Wildlifepics
[X]
p.1 #4 · 40d upgrade
Focus sometimes just seems to wander off target for no reason then its tough to regain .
Jan 06, 2009 at 05:58 PM
Gary Petersen
p.1 #5 · 40d upgrade
Here's an animated .gif I shot just for giggles yesterday. It's three short bursts in AI servo with the Mk III and the 70-200mm f2.8 IS.
Gizmo
Focus acquisition is almost faster than I can push the button. Here's a single frame from one of the series.
http://www.pbase.com/alibaby/image/107873123.jpg
Jan 06, 2009 at 06:06 PM
Daan B
p.1 #6 · 40d upgrade
Aha, heard/read that before
About 1.3 vs 1.6... Yeah, you will loose some reach. But what is the extra reach good for when you can't get the bird in good focus?
Jan 06, 2009 at 06:08 PM
Ian.Dobinson
p.1 #7 · 40d upgrade
Is that because the 40d does not have any assist points? Keeping a BIF bang on focus point is not easy.
Can you hire/borrow a mk2 to see if it does the job you want?
Jan 07, 2009 at 06:24 AM
Matt Philbin
p.1 #8 · 40d upgrade
What type of lighting are you shooting in? I went from 20d to 40d and saw major improvements for BIF. I would think the move upwards into any of the 1- series bodies would be significantly better, especially when you're using a relatively slow (5.6) lens. Not knocking your setup...check my profile. Just saying that when it's nice & sunny out, my 40D & 400 5.6 is stellar for BIF...when it's darker or cloudy - not as great.
Jan 07, 2009 at 08:11 AM
martines34
p.1 #9 · 40d upgrade
Philbin is right.
No contrast then the 5.6 lens can't perform.
I ended up getting a 135 mm f 2.0 and a 200 mm 2.8 for those situations (early morning and cloudy days) to get BIF.
Doesn't matter if you are using a 40 D or a 1 Ds MK II - same lousy results.
Jan 07, 2009 at 08:35 AM
