Sports Corner Rules
Sports Corner Resource
Archive 2009 · HELP WITH ARENACROSS SHOOT PLEASE
pepperman
p.1 #1 · HELP WITH ARENACROSS SHOOT PLEASE
Hi,
I have been given a pass to shoot an indoor arenacross motorcycle race and don't have a clue about what I should expect. I am shooting with a 1D MkIII and I was thinking that my 70-200 f/2.8 might be a good choice. If anyone has any experience with indoor shoots such as this and can share with me any helpful points, I would greatly appreciate it.
Thanks in advance.
Peace & Blessings,
Stuart
Jan 06, 2009 at 08:16 AM
trenchmonkey
p.1 #2 · HELP WITH ARENACROSS SHOOT PLEASE
Depending on your access, the 24-70 should be on hand too.
Jan 06, 2009 at 08:26 AM
pepperman
p.1 #3 · HELP WITH ARENACROSS SHOOT PLEASE
Thanks TM, I thought about putting the 24-70 on the 20D but was not sure if it would be good under these conditions? I will make sure that I have it one way or another.
Jan 06, 2009 at 09:13 AM
svRob
p.1 #4 · HELP WITH ARENACROSS SHOOT PLEASE
I am a HUGE fan (Blog Stalker) of Mark Rebilas and his sports shots, he's off the chain and is always trying something new.
One of the things I like best is how he walks you through what he has done...... check out his X Games shots. He talks a lot about remote trigger but you'll see his stadium work as well.
http://markjrebilas.com/blog/2008/10/from-the-archives-x-games-handlebar-remote-cam-2006/#more-1331
Jan 06, 2009 at 09:53 AM
cobra314
p.1 #5 · HELP WITH ARENACROSS SHOOT PLEASE
The 70-200 will be excellent and the 24-70 will be good too. If you aren't very experienced with shooting motocross then pay special attention to where you can/can't go. I've shot a good bit of AX racing in the past few years and they generally don't limit you like they do in Supercross. Be sure to always keep your front to the track and pay attention to the riders (especially around the whoops section). It doesn't take much for one of them to lose control and take out you and your equipment. I know from experience. Most of the arenas that I shot in had poor lighting. I generally used my 1D with 70-200 and 550ex flash.
Jan 06, 2009 at 12:50 PM
ftemoto
p.1 #6 · HELP WITH ARENACROSS SHOOT PLEASE
Boy, that's an understatement!
Jan 06, 2009 at 02:48 PM
Squid31
p.1 #7 · HELP WITH ARENACROSS SHOOT PLEASE
70-200 will do just fine, but if you have a 300 2.8 I would bring it as well. Crank the iso up (like 3200-or better) for head on shots and try to keep your shutter around 1250. You can pan from the side with a shorter lens and use much slower shutter speeds.
Jan 06, 2009 at 04:14 PM
sixone3
p.1 #8 · HELP WITH ARENACROSS SHOOT PLEASE
Alot of info on indoor shooting here... yes its ten pages, but you'll find info form one of the best in the business
http://www.vitalmx.com/forums/Photo-and-Video,23/Anyone-got-any-photo-question,15932
Jan 06, 2009 at 06:32 PM
redrider1197
p.1 #9 · HELP WITH ARENACROSS SHOOT PLEASE
If you can crank up the ISO and shoot wide open all the better - especially if you are able to get in close - avoid the flash if at all possible the racers will appreciate not being blinded by a flash.
Jan 06, 2009 at 08:11 PM
sixone3
p.1 #10 · HELP WITH ARENACROSS SHOOT PLEASE
Me being a racer myself.... i have never once been affected by a flash. And also taking pictures at all the races i attend (every weekend) not once has anyone ever been bothered by a flash. just my 2 cents.....
Jan 07, 2009 at 01:07 AM
cobra314
p.1 #11 · HELP WITH ARENACROSS SHOOT PLEASE
I have always shot with an iso of 200-400 and always used flash. All of the riders that I have ever talked to said they do not even notice the flash.
Jan 07, 2009 at 12:52 PM
Image Group
p.1 #12 · HELP WITH ARENACROSS SHOOT PLEASE
Which Arena are you shooting at? I shoot the MX at Qualcomm every year and I gear up with a 24-70, 70-200 and a 300 2.8. That usually covers everything. Also, just about every shooter there uses flash.
Jan 07, 2009 at 03:04 PM
barP
p.1 #13 · HELP WITH ARENACROSS SHOOT PLEASE
arenacross tracks are pretty tight and usually in small venues, so the 300 might end up just being extra luggage, depending on your access level. when i shoot supercross, i rarely even use it on the floor. don't worry about flashing the racers - i've been on both sides of that, and it's not an issue. as has been mentioned, though, high iso is your friend! shooting mx at anything below about 1/500 will challenge you, especially as a noob. one thing not said is that white balance will probably be hassle. the lighting will be dim, but it will also probably be weird colors, sometimes changing in different track sections.
oh....and lastly, don't listen to a thing squid31says. he's canadian!!
wp.
Jan 08, 2009 at 05:46 PM
j-bo
p.1 #14 · HELP WITH ARENACROSS SHOOT PLEASE
I've only shot indoors at 1600ISO with fill flash at 2.8 to keep shutter speeds up and have somewhat fair results, but I'd love to shoot lower ISO to rid the noise.
Full flash at lower ISO, but a limited 1/250 shutter speed?
What other typical settings are used? IdII is what I am using with a 440EX flash.
Jan 10, 2009 at 12:30 PM
barP
p.1 #15 · HELP WITH ARENACROSS SHOOT PLEASE
not sure about the 440ex, but you should be able to set high speed sync. the penalty is a loss of flash power, though.
wp.
Jan 11, 2009 at 03:16 PM
