Archive 2009 · 100-400 on tripod
SCOR
p.1 #1 · 100-400 on tripod
What would you all do in a situation where the wind is howling and you are taking long exposures shots (20-30 sec) with a 100-400 - IS or no IS?
I know the 100-400 does not have tripod sensitive IS, but if the wind is blowing enough to see the lens moving in the viewfinder, do you think IS helps more than it hurts?
thanks
Jan 06, 2009 at 03:10 AM
mrd08
p.1 #2 · 100-400 on tripod
none IS imho
Jan 06, 2009 at 05:29 AM
KiboOst
p.1 #3 · 100-400 on tripod
I've done a lot of them in a 25knt wind this summer ! 400mm, ND grad, no IS, but Gitzo serie 5 with markins and my bag at the bottom of the column. Exceptionnal sharpness on 1DsII, exposures between 20 and 30secs. Was even surprised myself !
Jan 06, 2009 at 06:20 AM
Xavier Rival
p.1 #4 · 100-400 on tripod
When doing long exposures with a 100-400 and wind, I think the only satisfactory solution is to use a solid tripod, as KiboOst did. The 100-400 is a rather large lens when extended, and not so heavy so wind can really cause it to vibrate. I do no think IS helps much on anything that long.
Jan 06, 2009 at 12:40 PM
matt4626
p.1 #5 · 100-400 on tripod
I have never had much luck with the 100-400 on a tripod if the IS is on. The only exception is a Wemberly head that is NOT locked down IMHO.
Jan 06, 2009 at 01:10 PM
CKrueger
p.1 #6 · 100-400 on tripod
I simply stand between the tripod and the wind. That cuts it down quite a bit.
You might also try taking the hood off the lens, if it's not too sunny out. That thing is an absolute wind sock!
Jan 06, 2009 at 01:57 PM
Utzly
p.1 #7 · 100-400 on tripod
A simple test will answer your question.
Take several shots with and without the IS and test the results
Don't forget to tell us which is better!
IMHO
Jan 06, 2009 at 02:19 PM
Cliff L.
p.1 #8 · 100-400 on tripod
thanks
It won't make much difference on that lens.
Jan 06, 2009 at 02:58 PM
