Scott Clark Offline Upload & Sell: On
I just finished putting the final stuff together for my quad core...I upgraded from a dual core. I've got 4 gigs of RAM, true hardware RAID (1 TB in a mirror for storage). I was using a 600 watt PSU, but I upgraded to a Power PC & Cooling 750 watt Silencer (it really is quiet). It's definetly a step up from my dual core machine. Everything is faster, but probably the biggest difference is how well it runs with everything I use open...I can run LR, Fireworks, Dreamweaver, Firefox (with like 20 tabs open ), etc, and it still just scoots along. With only one or two applications open, it really screams. Not that it matters for photography, but just to show how much faster it is...it used to take an hour and a half to encode an .avi file to a DVD. Now? 23 minutes .
Scott, if its that fast, I think I'll get me some quad core - one of the biggest issues is running more than one at a time.
I've just finished editing a wedding which took probably triple the normal time it usually does most likely because my hard drive is gradually getting more and more clogged up with photos I'm afraid to delete. Even though I have back ups.
You bet. Multiple cores were really designed with multi-tasking in mind, so it shouldn't be huge surprise when that's where they really shine. I'm still amazed at how much faster it is with CPU intensive operations though. And my dual core wasn't exactly slow either.
And you should get your photos off your OS drive if you can...storage is cheap, and a couple hundred dollars spent on a pair of SATA drives is money well spent. An external drive is easy to hook up, but building a RAID 1 array is easy, and relatively inexpensive too (and you never have to remember to back it up, it's there automatically in real time). Archive all your stuff on the array, and you'll never need to worry about deleting it. Just set up a file structure that will keep it organized, and leave it there forever if you want...
And as already pointed out, a fresh install is a nice way to start off your new hardware...
