Archive 2009 · 500D on Step-Up Ring?
photo1a
p.1 #1 · 500D on Step-Up Ring?
I want to use a Canon 500D on a 70-200 f/4 lens. The 70-200 f/4 is a 67mm lens. Canon does not make a 500D at 67mm. I have the 77mm 500D. Can I use a 67mm to 77mm step-up ring? Will the distance from the 70-200 to the 500D as a result of using the step-up ring cause distortion, or simply increase the magnification?
Jan 04, 2009 at 11:07 AM
Greg Feldman
p.1 #2 · 500D on Step-Up Ring?
You can use the step-up ring. I've used a 77mm 500D on the 100mm macro (58mm filter thread) before.
Jan 04, 2009 at 11:52 AM
G. Thomas
p.1 #3 · 500D on Step-Up Ring?
Do you think the bigger sized 500D's produce better images on smaller filter rings? You know, kind of like stopping it down?
Jan 04, 2009 at 12:22 PM
photo1a
p.1 #4 · 500D on Step-Up Ring?
Thanks, Greg.
Jan 04, 2009 at 01:46 PM
simony
p.1 #5 · 500D on Step-Up Ring?
for some reason, I can't get the focus working on 70-200 f/4L IS with the 500D on a67-77mm step up ring...
what am I doing wrong?
Mar 01, 2009 at 02:44 PM
Dave In La
p.1 #6 · 500D on Step-Up Ring?
set the focal length(zoom) and focus manually.....you get exact focus by slightly moving yourself fore and aft. Others may elaborate more.....or in better detail
Mar 01, 2009 at 02:50 PM
photo1a
p.1 #7 · 500D on Step-Up Ring?
I use the 500D with step up ring on my 70-200 f/4. Follow Dave In La's suggestion. Manual focus is the ticket.
Mar 01, 2009 at 05:53 PM
Pixel Perfect
p.1 #8 · 500D on Step-Up Ring?
Step-up ring is perfect solution and I also use the same idea for polarizers.
Mar 01, 2009 at 06:41 PM
EB-1
p.1 #9 · 500D on Step-Up Ring?
No. I have tried it on similar mixes (Nikon/Canon) and it should not be a problem. You will probably want to shoot at f/8 or smaller on any case for DOF.
Mar 01, 2009 at 06:53 PM
Pixel Perfect
p.1 #10 · 500D on Step-Up Ring?
Unless you are looking for some soft focus artsy effects, you do need to stop the lens down a fair bit with the 500D to get really sharp shots.
Mar 01, 2009 at 07:37 PM
mttran
p.1 #11 · 500D on Step-Up Ring?
I don't know the step up ring will work with the hood
Mar 01, 2009 at 07:43 PM
Pixel Perfect
p.1 #12 · 500D on Step-Up Ring?
Hood doesn't work with 500D anyway.
Mar 01, 2009 at 07:44 PM
