Archive 2008 · Umbrella vs. a Small Softbox
crockett
p.1 #1 · Umbrella vs. a Small Softbox
This fall I did some senior portraits with a decent level of sucess, using an off camera flash and 42" shoot through white umbrella.
Recently, I've come across this product by photoflex and it seems quite appealing.
http://www.photoflex.com/Photoflex_Products/Small_LiteDome_Kit_with_Swivel_and_Stand/index.html
Basically a 16" x 22" softbox that will allow me to mount a 580 EX to.
Could someone with more experience using softboxes explain the differences I would see vs. using a 42" shoot through white umbrella as far as the quality and coverage of light.
Of the top of my head, I would think the umbrella would give a larger area of soft light but the softbox would be much more efficient because all of the light really only has one direction it can go.
I was thinking for 1/2 body to headshots this would be quite a nice option because if it is indeed more efficient I would be using a bit less power from the flash, allowing me to shoot a bit more quickly.
I'm not so sure I want to purchase another item when the umbrellas are so cheap and worked so well for me.
Thanks.
Dec 28, 2008 at 04:26 AM
k7xd
p.1 #2 · Umbrella vs. a Small Softbox
Easy answer, control.
A shoot through sprays a nice soft light everywhere.
A softbox will let you control where the light goes much better.
Dec 28, 2008 at 04:48 AM
bobbyz
p.1 #3 · Umbrella vs. a Small Softbox
The kit youmention is a quite nice. Phil (pfiltz) from
http://www.keepsakephotography.us/
uses it for his senior shots.
Dec 28, 2008 at 06:48 PM
Richard Ersted
p.1 #4 · Umbrella vs. a Small Softbox
A softbox can be quite portable, too.
For example, Lastolite's EzyBox -- used with the optional handle -- is quite mobile.
The EzyBox was recently used by Moose Peterson, the reasonably well-known Nikon shooter, to shoot a quick indoor holiday portrait (see the second photo; Moose compresses his images significantly so the resulting *.jpeg quality is very poor, in my opinion).
And a photographer for ESPN Magazine -- Mark J. Rebilas -- recently used a softbox -- Photoflex? -- tied to a monoblock light
here [in the alternate, the box is shown in the eleventh photo from the top here.
edit: the Photoflex product -- seen via your link above -- looks well-priced.
Richard
Dec 28, 2008 at 06:58 PM
butchM
p.1 #5 · Umbrella vs. a Small Softbox
Actaually Phillip uses the 12x16 ... but he is continuing to consider the 16x22.
Where the softbox really shines as compared to an umbrella, is control .... less spill especially with the 16x22 has a recessed front diffusion panel and will also accept masks, louvres and grids ... although these items are expensive from the manufacturer, due to the smaller size, fashioning your own is quite easy.
Best thing about the Photoflex 16x22 is it works equally well with studio mono lights, just need the proper speed ring for your lights. For use with a speedlight, the kit has everything you need.
Dec 29, 2008 at 03:58 PM
crockett
p.1 #6 · Umbrella vs. a Small Softbox
Now that I know I can use it with mono lights, I'm going to get it! If I prefer the umbrella, I'll always have a smaller softbox for future studio use.
Another reason I was considering it is that when using the umbrella for an outdoor senior portrait session, even the slightest breeze grabs the umbrella. This seems a lot let less likely to pick up small breezes.
Usually, my daughter assists me so it's not that big of a deal, but not always.
Thanks!
Dec 29, 2008 at 05:48 PM
bobbyz
p.1 #7 · Umbrella vs. a Small Softbox
Go with small 16x22 photoflex SB, you will be happy.
Dec 30, 2008 at 12:04 AM
jcolman
p.1 #8 · Umbrella vs. a Small Softbox
I have that identical softbox and use it quite a bit. I got bored one evening and decided to shoot some tests with it compared to my large umbrella. Here are the results.
softbox 15' away
umbrella 15' away in reflective mode (not shoot thru)
umbrella 15' away in shoot thru mode
softbox light pattern
umbrella light pattern
hope this helps.
Dec 30, 2008 at 03:47 AM
Beni
p.1 #9 · Umbrella vs. a Small Softbox
Test seems to show the difference pretty well, the umbrella will wrap the light around much more, softbox is more directional. If you use a shoot thru brolly then you also have to consider the light hitting the ceiling and providing bounced fill. I actually use it like that on purpose for a very soft main light using softboxes for the more directional kicker lights.
Dec 30, 2008 at 05:39 PM
butchM
p.1 #10 · Umbrella vs. a Small Softbox
The samples are nice ... but I can't recall the last time I worked with a light source 15' from my subject, especially for an individual. Where you will see the biggest difference between the use of a softbox or an umbrella is when you have the source as close to the subject as possible and keep the modifier out of frame. That is when you see the difference between them and when the "wrap" of the softbox will be more pronounce.
Here is a link to a test shot I did when I first purchased the kit referenced by the OP the softbox is just a fraction of an inch out of frame camera left.... Oh Adorama often has the kit on sale with free shipping.
http://www.fredmiranda.com/forum/topic/618846/3?keyword=Photoflex,mini,softbox#5962755
Dec 30, 2008 at 05:55 PM
shatterkiss
p.1 #11 · Umbrella vs. a Small Softbox
Agreed. Especially with a small softbox, at that kind of distance you might as well just be stacking diffusion gels over a bare head, since spill control is no longer an issue.
I've got the little Photoflex LightDome XS around here somewhere...it is a great little tool for portraiture on the run, whether with hotshoe flash or real strobes. But it's definitely meant to be gotten up-close and personal with. I think it works especially well when used outdoors with daylight knocked down a stop under camera exposure - you get a nice richness from it with really appealing shadow depth. Just put it 2-3' away from your subject and let 'er rip.
Dec 30, 2008 at 06:16 PM
crockett
p.1 #12 · Umbrella vs. a Small Softbox
shatterkiss,
That was pretty much my "go-to" technique this fall with seniors outdoors. Put the umbrella as close as I could and drop the ambient 1-2 stops.
It will be interesting to see what the Photoflex does differently using this technique. However, I think I'm going to purchase the small rather than the XS.
Good thread and good info. Thanks all.
Dec 31, 2008 at 12:32 AM
jcolman
p.1 #13 · Umbrella vs. a Small Softbox
good point and I should have posted the close in shots that I also shot.
These were shot with the light source about 3' from the handsome gentleman.
Shoot thru umbrella
umbrella reversed
Softbox
As you can see, the biggest difference between 15' away and 3' away is in the shadow side of the face.
Dec 31, 2008 at 03:55 AM
