RDKirk Offline Dedicated FM Upload & Sell: Off
p.1 #6 · 250W/s Monolight = 250W bulbs? | |
1. I noticed in the second link that the mono lights output was listed in "real" and "effective" the former being higher. Since I can't find this with other mono light brands what is the difference between those two ratings?
Ignore the "effective" rating. If you see a rating listed as "real" or "true" or no qualifier at all, use that to compare with others.
Watt seconds refers to the energy capacity of the capacitors used in the flash--the total amount of energy it stores for a maximum-power flash. Some flash systems are slightly more efficient than others so you can't draw an exact comparison, but that's the only universal rating for comparison we have to use (a joule is equal to a watt second, btw).
Generally, you can consider flash units within 50 watt seconds of each other to be equal.
2. Is shutter speed set to a constant like 1/200 for example?
Yes. Sometimes a camera requires a slightly slower sync speed (maybe 1/2 stop slower) than its rated maximum with studio electronic flash, especially with accessory wireless triggers. But the shutter speed is kept constant in use--you vary exposure by varying the aperture, the flash power setting, or the distance of the flash from the subject.
