davekone Offline Dedicated FM Upload & Sell: On
p.1 #3 · Flash and Height and Quantum | |
It is possible to get red eye even with a flash bracket but it should reduce the chances greatly.
Bounce the flash off a wall or ceiling. Use a Joe Demb Flipit on your flash to bounce and spread the light.
Now since you told me you are in a wheelchair I instantly got some neat ideas!
Mount the flash on a monopod and strap the mono pod to the back of your wheelchair, get the flash up above like 6 feet. You also have the option of using two flashes attached to your chair on on each side, this will make them work less and recycle faster. You could use a quantum 2x2 attached to your chair and drive both flashes. You will then need a remote trigger like Cyber Syncs.
http://www.alienbees.com/remotes.html
Get creative you have some options here. Many photogs run around with light on a wheeled light stand and push it around.
I had a Quantum td5 and the bracket and weight of the thing got in my way! The light was great though! You have the option of attaching it to your chair thus eliminating this problem. Use your 580ex II for now and work things out, I do not think the t5d will improve what you are doing much, the 580 is quite powerful and cycles faster with a battery pack.
