Not to be cruel but the diamond looks like you just pulled it out of the mud. The diamonds in general have not flash. Think you getting closer but this is not acceptable in my opinion. Best of luck.
more context, link the image to something iconic from the day. if it was a beach wedding, use sand, if they are playful, use bright colors, something, otherwise it looks just the same as that funny rock-encrusted thing they have on their hand already.
I'm diggin' the composition. The blurred bkgnd totally works for me. It looks like you caught some ceiling reflection, or reflection in the facets of the area in front of the ring,maybe?
The posing is creative..note to myself. Nicely done.
thanks for your comments everyone Not to be cruel but the diamond looks like you just pulled it out of the mud
I did notice this on the night in an earlier shot and tried to clean the ring the best I could but without a soft brush i couldn't get behind the diamond to clean it.
But what is that white thing inside of the diamond?
Its the reflection from the flash
Point taken, thank you. I looked around for about an hour for something interesting, but unless i used the flowers (which is a shot I'm personally bored with) there wasn't anything. I did do some shots with the christmas decorations but I wasn't happy with them and the couple were avoiding christmas themes on the day.
Thank you, that was what I was trying to go for
Thanks, I was trying to do something to show off both of her rings as I thought they were pretty.
I agree with the other posters. The rings were not adequately prepared for this shot. The diamond looks dirty and the way the rings were lit makes them look like they were badly scratched.
I'm glad you're happy with your results and if your client likes it, that's all that matters.
Yes, I now know to take a polishing pad and toothbrush with me in my emergency kit.
The rings were badly scratched, so there was no way away from it unfortunately, even from off camera flash, bouncing or direct flash. it just means work in PS.
The framing and the focus are good, but the lighting is too direct and harsh. Something more diffuse would work much better. Post processing that was slightly less contrasty would help as well.
As for lighting, bouncing the flash off the ceiling could work, or if that isnt an option, you might try going outdoors and using sunlight - either directly or diffused in the shade of a tree.
