FM Forums | Digital Art, Smartphone & Abstract | Join Upload & Sell
Archive 2008 · Photomatix Help
Bill Gass
p.1 #1 · Photomatix Help
Downloaded the pro 3.1 for the third time. When I try the single file conversion I always get an erro that says...
An unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attemt to continue. If you click quit, the application will be shut down immediately.
Anyone elase get this or know why it happens ?
Aslo, when usign the trial version it seems to flicker alot. Really weird.
Also, when generating and HDR image, I pick my three images and click the auto align but it never works
~Bill~
Dec 19, 2008 at 01:23 PM
Bill Gass
p.1 #2 · Photomatix Help
Anyone
Dec 20, 2008 at 03:41 PM
kdlanejr
p.1 #3 · Photomatix Help
I'm using 3.0.3 RC2 and do not have this problem. I'm not using a trial version, but when I was, I didn't see this issue either.
Here is a good place to learn a bit quickly (about using photomatix) and learn about settings that will help get you started.
If you continue to have an error with 3.1, I'd recommend trying to use a slightly older version just to see if the error goes away.
Dec 25, 2008 at 11:23 AM
DigiPI
p.1 #4 · Photomatix Help
Bill -
Maybe you could outline the steps you are doing? Are you to the point when you select the actual file? If so what type of file? Camera RAW, right?
Dec 31, 2008 at 08:16 AM
martines34
p.1 #5 · Photomatix Help
What type of computer are you using and what system do you have on it??
Have you contacted Photomatix with your problem??
Dec 31, 2008 at 08:30 AM
Bill Gass
p.1 #6 · Photomatix Help
DigiPI wrote:
Bill -
Been using jpeg on this computer and my one at work over the last year with photoshop 7 as a plugin.
Dec 31, 2008 at 08:56 AM
Bill Gass
p.1 #7 · Photomatix Help
Brand New Dell, Windows XP.
Not yet, but I should.
Justin Huffman
p.1 #8 · Photomatix Help
Hi Bill - Re: the alignment issue, are the original images shot using a tripod and some cable release?
Dec 31, 2008 at 09:05 AM
Bill Gass
p.1 #9 · Photomatix Help
Yes they were ( tripod and shutter release ) but it must of got moved or something because they are a little off. They are really close though and was hoping it would work.
Dec 31, 2008 at 11:13 AM
Justin Huffman
p.1 #10 · Photomatix Help
maybe re shoot something in the back yard to eliminate that possiblity.
Dec 31, 2008 at 04:41 PM
