Archive 2008 · Rokkor-X vs. Rokkor PG (58mm 1.2)
blackpill
p.1 #1 · Rokkor-X vs. Rokkor PG (58mm 1.2)
What's the difference between these lenses? After seeing tons of sample photos and rave reviews here, I'm very interested in getting myself a Rokkor X 58mm 1.2. I've seen some Rokkor PG's for sale? What's the difference? Which is THE lens to get? Thanks for the help.
Dec 18, 2008 at 09:00 PM
Jman13
p.1 #2 · Rokkor-X vs. Rokkor PG (58mm 1.2)
Not much difference. Same optical formula in all of them.
BTW...I'm selling mine already converted (Rokkor-X)...PM if you're interested.
Dec 18, 2008 at 09:04 PM
Anden
p.1 #3 · Rokkor-X vs. Rokkor PG (58mm 1.2)
As understand the coating is different and this might affect the results in some conditions. All are great lenses from what I have seen.
Dec 19, 2008 at 03:37 AM
cogitech
p.1 #4 · Rokkor-X vs. Rokkor PG (58mm 1.2)
The "X" is meaningless with respect to the lens design. It was simply added to some of the lenses depending on what market they were destined for. Sort of like how the "Digital Rebel" is a "300D" in some markets and a "Kiss Digital" in others.
The "PG" simply indicates the number of elements/groups in the lens design. In this respect they are all the same, regardless of whether it says "PG" or not.
I have had samples with the following names:
Rokkor
Rokkor PG
Rokkor-X
Rokkor-X PG
For example: http://www.cogitech.ca/Rokkor/crw_6747.jpg
They are all terrific lenses, but the best two (of many, many samples I have had) had serial #s 200xxxx and 250xxxx.
Dec 19, 2008 at 10:33 AM
blackpill
p.1 #5 · Rokkor-X vs. Rokkor PG (58mm 1.2)
Thanks for that Cogitech. That's exactly what I was looking to hear. Much appreciated.
Dec 19, 2008 at 10:45 AM
cogitech
p.1 #6 · Rokkor-X vs. Rokkor PG (58mm 1.2)
No worries.
If you end up getting one and you have any questions about the conversion, etc. or even if you'd like to share some shots, be sure to drop by http://forum.cogitech.ca/
Dec 19, 2008 at 11:01 AM
JimBuchanan
p.1 #7 · Rokkor-X vs. Rokkor PG (58mm 1.2)
My experience with MC 58/1.2 lenses is the markedly warmer color shift of the early lenses with metal focus rings. Although apparently completely reversible with a UV light treatment, it is surprising to see the difference, and requires an effort to bring the warm color back to neutral. This warmness is related to glasss discoloration of the higher refractive index , of the glass containing rare earth elements and can emit radioactivity.
So far, I have seen a very consistent, equivalent, infinity sharpness between all of them. Just to qualify, infinity focus is very absolute. There is no sharpness question, due to focus accuracy, as there is on short and medium distance tests. Lastly, all my observations are comparative. I have a reference lens, and sometimes 2 other lenses to compare, at the same time of day, same exposure, etc.
Dec 19, 2008 at 11:47 AM
