Archive 2008 · E-TTL strobe on emergency scenes
wuping
p.1 #1 · E-TTL strobe on emergency scenes
Can someone tell me a technique for improving exposure when using an E-TTl strobe on emergency scenes. It seems that each time I'm shooting fires, wrecks, etc which involve reflective tape on bunker gear, the image is underexposed. Tried using a bracket to raise the flash with no luck. The best option so far has been to use a Vivitar 283 in automatic mode. It gives great results, but hate to carry two strobes in the bag. Any information would appreciated.
Dec 15, 2008 at 01:35 AM
k7xd
p.1 #2 · E-TTL strobe on emergency scenes
No suggestions for using TTL as it is not reliable.
Just say no to point and shoot and use manual.
Dec 15, 2008 at 01:54 AM
Paratima
p.1 #3 · E-TTL strobe on emergency scenes
Amen. Learn the flash and memorize the pertinent settings. It shortly becomes "automatic".
Dec 15, 2008 at 02:00 AM
cgardner
p.1 #4 · E-TTL strobe on emergency scenes
The reflective tape used on fire gear has the characteristic of reflecting light at nearly any angle.
Evaluative metering, the default mode for Canon flash, keys off the highlights which is why you are getting under-exposure. Try setting flash metering to "average" via CF.n (on the camera) which should produce results similar to the average metering auto sensor on the Vivitar.
Manual will be more consistent and predictable. With a bit of testing you'll be able to quickly determine the power levels needed at various distances. Stick with one f/stop and set flash zoom manually to a fixed setting such as 24mm so the only variable is power level.
But if you look on the back of the flash in M mode you will see there is an indicator which shows the distance at which flash exposure will be correct which takes into account aperture and flash zoom setting. All you need to do is estimate the distance and then turn the power dial until the indicator on the back of the flash is over that distance.
Chuck
Edited on Dec 15, 2008 at 07:34 PM · View previous versions
Dec 15, 2008 at 05:08 AM
Carmen Miranda
p.1 #5 · E-TTL strobe on emergency scenes
It really makes you wonder how "Weegee" ever got by without E-TTL.
Art Fellig, the most famous ambulance chasing photographer that ever lived.
His 4X5 Speed Graphic used flash bulbs and was preset Manual to f16 at 1/200th.
Every shot he took was at 10'.
Heck, that's only a GN of 80. Should be a piece o' cake with a 580.
Good luck.
"We don't need no stinking E-TTL."
Edited on Dec 15, 2008 at 07:14 AM · View previous versions
Dec 15, 2008 at 06:41 AM
bacilonur
p.1 #6 · E-TTL strobe on emergency scenes
Or get a Metz 54 or 58 that can handle ETTL and Auto.
Dec 15, 2008 at 07:12 AM
c.d.embrey
p.1 #7 · E-TTL strobe on emergency scenes
Note how handle mount flash does not center over lens?
Millions of weddings were shot with Hasselblads using either Honeywell or Metz potato mashers. A lot of PJs also used these handle mount electronic flashes.
Wonder where I can find a Canon 480EG Speedlite handle mount.
Dec 15, 2008 at 07:50 AM
cgardner
p.1 #8 · E-TTL strobe on emergency scenes
Did he have a choice?
Flash was indeed much simpler before zoom lenses and flashes, especially with negative film, if you were systematic and shot from fixed distances with memorized f/stops for each distance based on testing. Been there, done that....
But given the choice I use a tool that let me choose between manual and E-TTL as the situation required. I bet Weegee would too
Chuck
Dec 15, 2008 at 12:27 PM
Carmen Miranda
p.1 #9 · E-TTL strobe on emergency scenes
Actually, it's quite likely he may have chosen Auto mode if there was reflective tape back in his day, as it would clearly be the superior mode in that situation. Assuming of course, that Canon was "progressive" enough to offer him the choice. Unfortunately Canon refuses to acknowledge that their E-TTL system has any limitations whatsoever. If there was one reason I'd consider switching systems it would be due to their flash system. So while I'm waiting for the 900 EXIII to show up, I guess I'll have to stick with my Metz or make the switch to Speed Graphic.
Good luck.
Edited on Dec 15, 2008 at 05:10 PM · View previous versions
Dec 15, 2008 at 04:14 PM
veroman
p.1 #10 · E-TTL strobe on emergency scenes
cgardner wrote:
Try setting flash metering to "average" via CF.n which should produce results similar to the average metering auto sensor on the Vivitar.
Chuck
Are you referring to CF.n 3 on the 580 EX flash?
This sets the flash in either ETTL or TTL. Option #0 is ETTL. Option #1 is TTL.
However, Canon's instructions are pretty clear about NOT using Option #1 for digital as that setting is intended ONLY for use with film cameras. Setting CF.n 3 to #1 will cause the flash either to misfire, fire at full output only, or not fire at all.
So ... I'm not sure what your recommendation actually is. Are you talking about a CF.n setting on the camera?
- Steve
Dec 15, 2008 at 04:58 PM
bacilonur
p.1 #11 · E-TTL strobe on emergency scenes
No, he's talking about on the body. C.Fn 14 (on a 1D2) is ETTL II: Evaluative or Average.
Dec 15, 2008 at 05:16 PM
veroman
p.1 #12 · E-TTL strobe on emergency scenes
Thanks....
Dec 15, 2008 at 05:24 PM
cgardner
p.1 #13 · E-TTL strobe on emergency scenes
That's not true.. Wouldn't you consider completely changing it admission the previous system didn't work well?
Canon film cameras metered off the film during the actual exposure in a direct feedback loop. Canon called it "TTL". The move to digital sensors prevented that so the metering shifted to the viewfinder, with flash metered before the shutter opened via pre-flash.
The first iteration of digital metering was called "E-TTL" by Canon. It based flash metering around active AF points and had an "auto fill reduction" algorithm based on EV level which could be turned off via CF.n.
Canon completely changed the metering system again around 2004 with the 20D and later bodies moving from E-TTL to E-TTL II which compares ambient and pre-flash over 35 zones (more on pro bodies) and also uses focus distance information from most USM lenses (but only when flash is used directly).
One of the reasons I didn't jump into the DSLR game until the 20D arrived is negative feedback about how much the AF point based E-TTL sucked. The introduction of E-TTL II in the 20D appeared to solve most of those problems. But it wasn't until I wrapped my brain around how evaluative metering works that I figured out how to get good results with Canon E-TTL II: don't try to out think it. Point, shoot, evaluate, adjust.
Evaluative compares zones and finds the brightest ones, then decides whether they are specular reflections or areas of important detail. By comparing ambient light zone-to-zone which isn't affected by camera / subject distance with flash returns, which are affected by distance, the camera and create a rough 35 zone radar-like map of what is in the viewfinder.
So if using evaluative you can look in the viewfinder, spot the area of greatest flash reflection and know evaluative will err on the side of not blowing the highlights there. If that brightest area of reflectivity isn't closest to the camera and your intended center of interest your COI will wind up underexposed. But what you need to realize that correctly expose that middle-ground with any flash, manual or auto, you will only be able to to that by over-exposing the foreground which is equally undesirable.
So if anything using E-TTL II evaluative metering teaches you to compose flash shots more effectively, putting what is more important in the foreground ensuring better odds of correct exposure. But since it can't precisely meter the scene - there are only 35 large zones - some FEC adjustment will nearly always be necessary to make the exposure perfect.
The technical Albatross of DSLRs is the "R" the reflex mirror. Lose the mirror and use an Electronic Viewfinder instead and the sensor will dump and read the contents of the sensor 30-40 times per second or more. While its processing the data for the EVF it can also evaluate, down to the pixel level of detail, what areas are clipping. That's why some P&S cameras seem to do a better job of exposure control than a DSLR.
Live view? That's just Canon's way to start weaning still camera users away from optical. After all the video side of the house has lived with EVF since its inception. I have an EVF on my Minolta D7Hi and given the choice between an APS-C Canon with EVF and better metering vs what is offered now I'd take the EVF version in a heartbeat.
Chuck
Dec 15, 2008 at 08:08 PM
veroman
p.1 #14 · E-TTL strobe on emergency scenes
Chuck: that's a really informative piece you've written above. Very helpful, interesting read. Thanks...
- Steve
Dec 16, 2008 at 01:23 AM
digitalbug30d
p.1 #15 · E-TTL strobe on emergency scenes
Is this DPR? it would be nice if people would help others not with sarcastic remarks like the above..people of all abilities come here for this very reason..
Dec 16, 2008 at 01:38 AM
wuping
p.1 #16 · E-TTL strobe on emergency scenes
Thanks for everyone’s response. Tried average metering through the custom function with positive results. That was definitely a step in the right direction.
Dec 16, 2008 at 11:59 PM
