FM Forums | Lighting and Studio techniques | Join Image Upload
Rear curtain sync with ABs? Go to previous topic Go to next topic
jprezant
Buy and Sell: On
p.1 #1 · Rear curtain sync with ABs?
Is there a way to get Alienbees to rear curtain sync for action shots?
Dec 08, 2008 at 10:38 PM
bacilonur
Buy and Sell: On
p.1 #2 · Rear curtain sync with ABs?
PW Multimax is the only way AFAIK.
Dec 09, 2008 at 12:33 AM
BSHuff
Image Upload: Off
p.1 #3 · Rear curtain sync with ABs?
The AlienBee factor here is insignifigant as it is a 'dumb' unit that fires when your trigger signal says so. So you need to have your trigger signal provide the rear curtain.
I am pretty sure Nikon provides rear curtain through the sync port when the camera is set to rear, but Canon only puts out a first curtain sync no matter the camera setting
The PW MultiMax can 'create' one, you tell it a delay and it creates the rear curtain by delaying the initial pulse it gets from sync.
someone with some electronics experience could create a delay box that could work too, but that would be a tinker type project that would need to be tuned, so it would not really work for fast action.
Dec 09, 2008 at 03:26 PM
NinaS
Image Upload: Off
p.1 #4 · Rear curtain sync with ABs?
my Canon bodies allow me to set the rear curtain sync on the body, this means that the camera will fire (any flash unit) at the tail end of the shutter fire
... this is great for 30s exposures of models at night & such
Dec 09, 2008 at 04:06 PM
bacilonur
Buy and Sell: On
p.1 #5 · Rear curtain sync with ABs?
AFAIK, that's only for speedlights.
Dec 09, 2008 at 04:10 PM
bobbyz
Buy and Sell: On
p.1 #6 · Rear curtain sync with ABs?
Why not put a speedlight on camera and let the ABs trigger optically from it? Not an ideal thing but should work.
Dec 09, 2008 at 04:49 PM
jprezant
Buy and Sell: On
p.1 #7 · Rear curtain sync with ABs?
b/c the optical triggers on AB's are terrible. If you have a modifier on the AB, and its facing you...it drastically reduces the effectiveness of the optical trip.
Dec 09, 2008 at 08:28 PM
RDKirk
Image Upload: Off
p.1 #8 · Rear curtain sync with ABs?
That only works for Canon-dedicated flash units.
Dec 10, 2008 at 02:49 PM
Lost password?
