Moderated by: guardian
FM Forums | Lighting and Studio techniques | Join Image Upload
Archive 2008 · Ring flash & redeye Go to previous topic Go to next topic
DannyG
Image Upload: On
p.1 #1 · Ring flash & redeye
Why don't you see redeye using a ringflash? I would think having a light source that close to the lens would make that happen.
I'm confused.
Dec 04, 2008 at 11:11 PM
bacilonur
Buy and Sell: On
p.1 #2 · Ring flash & redeye
You will if you're shooting in the dark and don't have the modeling lights turned on.
Dec 05, 2008 at 04:13 AM
DannyG
Image Upload: On
p.1 #3 · Ring flash & redeye
Thanks. I looked into 'The Google' and found a couple of articles that said the same. I still can not get past the idea of ALL the pictures not having horrid amounts of red-eye.
Dec 05, 2008 at 04:29 AM
bacilonur
Buy and Sell: On
p.1 #4 · Ring flash & redeye
Well, a lot of ring flash shots are taken fairly close up so that the ring catchlights can be fully appreciated, and you'll usually have 2-3 inches between the lens and the actual bulb, so that helps it to not be too direct. I rarely get redeye while using on-camera flashes aimed directly at the subject because it's a good few inches above, unlike P&S cams where the lens is literally right next to the flash.
Dec 05, 2008 at 04:32 AM
shatterkiss
Image Upload: Off
p.1 #5 · Ring flash & redeye
I suspect it could also have something to do with the relative size of the light source as well: a ringflash is effectively, what, maybe 8x the diameter of the head of a Speedlight? I don't get redeye with a medium softbox positioned right over the camera either, nor a big octabox right behind the camera. Not sure I've gotten redeye using Speedlight modifiers like Lumiquest ProBounces or mini softboxes either.
Honestly, none of the ringflashes I've used have modeling lights, so I'm not convinced that's a factor. But I'm just guessing here.
Dec 05, 2008 at 04:42 AM
ICQ
DannyG
Image Upload: On
p.1 #6 · Ring flash & redeye
Good points. Thanks for the help.
Dec 05, 2008 at 05:02 AM
ajmichael
Image Upload: Off
p.1 #7 · Ring flash & redeye
It's perfectly possible to get redeye with a ring flash - trust me! :-)
Andy
Dec 06, 2008 at 06:26 PM
Lost password?
