Archive 2008 · Lamp recommendation
Rebel Guy
p.1 #1 · Lamp recommendation
I've been doing nightclub fashion runway style shots lately with my 20D and 430EX I...and just got a CB mini bracket...but now doing some portraits with they models just with the 430. I also have a Smith Victor KT500U, 2-LIGHT 500 TOTAL WATT KIT WITH UMBRELLAS... they use Tugsten bulbs....
Any recommendation on better bulbs to use? Flourescent or Halogen or ?
I'm here in SoCal for some local stores or I can buy online.
Thanks for any feedback.
-Frank
Dec 02, 2008 at 06:33 PM
ngphoto
p.1 #2 · Lamp recommendation
Hi Frank
I did a little looking around For some Day light temp. halogens and could not find a thing. Easy to find fluorescent here is a link that will help you, it is a 85watt=300 fluorescent that is 5000k temp. the price is cheap $25 each hope this helps you and Good luck.
http://www.cowboystudio.com/product/15686/Daylight-85-Watt-5000K-Photo-Fluorescent-Light-bulb_198308.html
Nathan
Dec 03, 2008 at 04:02 AM
runamuck
p.1 #3 · Lamp recommendation
I almost started a fire using halogens. Never again. They are now part of a landfill somewhere.
CFL's are far better in your fixtures. No heat, no blown circuit breakers, no flicker, and you can actually see the results of lighting changes.
I checked resellerratings.com and found no mention of cowboystudios. Has anyone dealt with them?
Dec 03, 2008 at 04:22 AM
Rebel Guy
p.1 #4 · Lamp recommendation
Nathan, thanks for the info. Are Fluorescent bulbs better than Halogen which are better than Tugsten?
Thanks.
-Frank
Dec 03, 2008 at 04:43 AM
bacilonur
p.1 #5 · Lamp recommendation
Those are continuous lights, right? You'd be much better off with some cheap Alienbees or even just a couple manual hotshoe flashes. They'll put out much more light than you'll ever get from 500 watts of continuous light.
Dec 03, 2008 at 06:41 AM
ngphoto
p.1 #6 · Lamp recommendation
The main thing to think about is how much time do you want to spend in Processing your photos. If you look around it is hard to find a 4800+deg. kelvin Halogen that is cheap and that last more then 4 hours at 250 watts. It is not hard to find 4800k Fluorescent bulb that will last you 5 years or more of uses. Yes Bacilonur is right if you have the money to do so.
If you are really getting in to It and are getting Paid for Then spend the money, But if Not go with fluorescent they are cheap.Then work your way in to some Monolights.
Good luck
Dec 03, 2008 at 07:21 PM
ngphoto
p.1 #7 · Lamp recommendation
Hi again
I found the Fluorescent on Amazon, here is more info about COWBOYSTUDIO.
http://www.amazon.com/gp/offer-listing/B001ME7GPU/ref=dp_olp_0?ie=UTF8&qid=1228276416&sr=1-2&condition=all
Dec 03, 2008 at 09:52 PM
cwebster
p.1 #8 · Lamp recommendation
The two biggest problems with using CFLs for photo lighting is 1. they aren't bright enough (so you end up shooting at ISO 1600 and f/2.8 at 1/60) and they aren't dimmable. So you can't put a fill light up close, so it's soft and wraps around the subject, without it being too bright.
CFLs are also notorious for not being consistent color / temp. Just because 2 CFLs have the same CRI or color temp, doesn't mean they will actually match when you start shooting.
Like bacilonur, I suggest you get one entry-level studio strobe, like an AB and learn from there. You won't learn much about studio lighting with lights you can't control.
<Chas>
Dec 03, 2008 at 10:03 PM
runamuck
p.1 #9 · Lamp recommendation
ngphoto wrote:
Hi again
Thanx for the info.
Dec 03, 2008 at 11:50 PM
Rebel Guy
p.1 #10 · Lamp recommendation
Thanks ngphoto for you time researching for the CFL's for me!
Dec 04, 2008 at 06:32 AM
