Archive 2008 · 30d dim dataline
adamc
p.1 #1 · 30d dim dataline
Hi,
I recently purchased a used 30d and noticed that the viewfinder data line is dim and hard to read. For example, it's hard to tell if I see 2.0 or 2.8. Some of th "bars" that make up the number appear half-lit.
Is this an easy fix?
Thanks
Nov 27, 2008 at 02:24 PM
calemon
p.1 #2 · 30d dim dataline
The whole line is dim or just one letter?
The status line varies in brightness based on the input from a sensor in the viewfinder. I seem to recall having some kind of situation with dirt causing mine to temporarily misbehave, but I'm having trouble remembering all the details just now. If the whole line is affected yours is probably not reading ambient light correctly and operating as if pitch black.
Inspect your entire mirror box and viewfinder area for any debris which doesn't belong there.
Nov 27, 2008 at 03:35 PM
cwebster
p.1 #3 · 30d dim dataline
The 30D's viewfinder data is notoriously dim. I inquired just after buying mine 2 years ago and was advised "that's the way it is"
Mine is so dim that I can't see it at all if I'm wearing my sunglasses. So I have to change glasses whenever shooting outdoors in the sun
<Chas>
Nov 27, 2008 at 04:42 PM
dcains
p.1 #4 · 30d dim dataline
And, some were apparently just plain defective. Can you see the display change brightness in relation to ambient light? Simply move your hand in front of the lens - it should be obvious.
Nov 27, 2008 at 05:05 PM
adamc
p.1 #5 · 30d dim dataline
thanks for the replies.
It doesn't seem to vary with brightness (hand over front of lens test), it almost seems like it's just a bad LED Display.
Note: the exposure level stays solid and appears to dim slightly with varying brightness, but its the aperture, shutter speed and max burst that flicker constantly.
maybe it's just defective.
Nov 28, 2008 at 08:34 AM
