Archive 2008 · 100mm Macro users: Tech question
Greg Feldman
p.1 #1 · 100mm Macro users: Tech question
Question for users of the 100mm USM Macro: When looking through the lens while it's off the camera, and turning the focus ring, does it go from a "wide open" perfect circle to a more octagonal shape that almost looks like slightly stopped-down aperture blades? That's what mine is doing, and I wonder if it's faulty or if that's normal for this particular lens. At first I thought my aperture blades were stuck, but that wouldn't make sense given the wide-open change at one end of the focus throw. And when I mount the lens, stop down to f/4, and press the DOF preview button, the VF does get darker.
Thanks,
Greg
Nov 26, 2008 at 10:48 PM
mpmendenhall
p.1 #2 · 100mm Macro users: Tech question
Yes, I've seen that on mine too, and assume it is normal.
Nov 26, 2008 at 11:03 PM
p.1 #3 · 100mm Macro users: Tech question
Me too.
Nov 27, 2008 at 06:32 AM
Greg Feldman
p.1 #4 · 100mm Macro users: Tech question
Thanks, guys. I feel better. Can anyone explain what's going on when it does this?
Nov 27, 2008 at 09:58 AM
Ian.Dobinson
p.1 #5 · 100mm Macro users: Tech question
Isn't it that altough its a prime it is actualy changing focal length in order to get the magnifacation at the short end. IE its not always 100mm. so its actualy changeing the apature to keep the ratio to acheive the 2.8 Fstop.
I may be completely wrong, it happens (wife thinks it always happens ) but if you look at a constant apature zoom when you zoom from one end to the other you can see what you describe
Nov 27, 2008 at 10:26 AM
