Archive 2008 · Adding third light
hoghunter
p.1 #1 · Adding third light
I am an amateur photographer who is trying to expand his kit while still being on a budget. I shoot portraits for family friends and the holidays are a big time for me.
I have a Novatron two light kit. Like this this here is the Novatron page.
The kit has two lights and uses a household plug for the sync cord.
Yesterday I got a Photogenic Studio Max III on craigslist. It has a small plug for the sync cord that looks like a headphone jack.
I have a cord the goes between my hotshoe adapter and the Novatron using a household plug. I am shooting with a 50D.
My problem is how do I connect the new Studio Max light so it fires with the Novatron lights? I heard I can use a splitter for the audio jack by plugging into a headphone splitter. Another choice is to use the PC Sync terminal on the 50D. I haven't used it at all and I assume the hotshoe and the terminal can be used simultaneously. I don't know what kind of plug it uses.
On the strobist site it seems that this is not rocket science. I am pretty handy with a soldiering iron so I am tempted to create my own sync cable. Any suggestions?
Nov 25, 2008 at 03:03 PM
jscoby05
p.1 #2 · Adding third light
Why couldn't you just use the optical slave or an alienbees or ebay wireless trigger. Seems like a lot of cables to have all over your studio floor.
Nov 25, 2008 at 05:38 PM
hoghunter
p.1 #3 · Adding third light
Well the Novatron kit is a wired kit. The lights connect to a central power source and the power converter also syncs the flash. Having said that, I can use a wireless transmitter for the control of the Studio Max. With all of the lights the power comes via a wire. The Studio Max plugs into the wall the Novatron lights plug into the transformer.
Nov 25, 2008 at 09:58 PM
Carmen Miranda
p.1 #4 · Adding third light
The Studio Max has a optical slave built into the unit and should have a switch to turn it off or on. Turn it on and it will fire with your Novatrons. No need for extra cables.
Good luck.
Nov 26, 2008 at 12:14 AM
hoghunter
p.1 #5 · Adding third light
Good luck.
Hmm, are you saying it "sees" the Novatron light fire and fires with it?
Nov 26, 2008 at 09:02 AM
Carmen Miranda
p.1 #6 · Adding third light
Correctamundo.
That's what a "slave" does. Check the back of your Max.
Good luck.
Nov 26, 2008 at 09:52 AM
