Archive 2008 · No Shadow White Backround Help - Product Shoot
joesmosax
p.1 #1 · No Shadow White Backround Help - Product Shoot
I'm getting into product photography as a hobby and need some help shooting on a white backdrop with no shadows on the paper. I think the best way to achieve this is with light coming from below, I've heard frosted glass can be used? Or perhaps white plexiglass? What works best?
Right now I'm either washing out the product in an attempt to achieve a pure white or tweaking big time in photoshop.....
I have 4 decents strobes and two soft boxes and 2 umbrellas. I'm game for buying a light tent, though I figured soft boxes might give me more flexibility.
Thanks for the help.
-Joe
Nov 24, 2008 at 08:13 PM
c.d.embrey
p.1 #2 · No Shadow White Backround Help - Product Shoot
There are lots of ways to light product shots.
This has a Profoto Beauty Dish with grid pointing down on white plexi (BTW any brand 18" to 22" dish should work). If you bottom lit the plexi and removed the grid it would give a look you would like (you could also use a small/medium soft box). I used one of these as a shooting table http://www.calumetphoto.com/item/CB0915/ but a 4x8 piece of white plexi would work. If the plexi has a matte surface it would look like my shot. If it were shiny you would get a reflection of the product in the plexi.
This is just one way to do it. Product shooters have a very large bag of tricks.
Hope this gives you some ideas.
Edited on Nov 24, 2008 at 11:24 PM · View previous versions
Nov 24, 2008 at 10:37 PM
joesmosax
p.1 #3 · No Shadow White Backround Help - Product Shoot
ok great. Yes that helps. Is this plexiglass I can get at a hardware store, or is this something you special order? Thanks,
Joe
Nov 24, 2008 at 11:16 PM
cwebster
p.1 #4 · No Shadow White Backround Help - Product Shoot
The best info on shooting products, or anything else, in the studio is "Light - Science & Magic" It will explain what CD is saying that there are lots of ways to skin a cat.
Shooting straight down works for some products, but not for others. The small products in this gallery each required a different lighting set up. www.charlesLwebster.com/RSG_Prototypes/
Underlighting a product is often difficult because you have to carefully balance the under light and the key from above. The best way to achieve a white background is to move the subject away from it and light it separately as is often done for catalog photography.
<Chas>
Nov 25, 2008 at 12:54 AM
c.d.embrey
p.1 #5 · No Shadow White Backround Help - Product Shoot
Depends upon where you live. I'd try local hardware stores, plastic suppliers or sign shops. If they don't have it they should be able to order.
What you should try to find is 2447 Plexiglas, it has the highest light transmission. And matte on one side and shiny on the other is available. That way you have both on one sheet .
Nov 25, 2008 at 01:02 AM
c.d.embrey
p.1 #6 · No Shadow White Backround Help - Product Shoot
<Chas>
The best way is in the eye of the beholder. For catalog shooting Chas is probably right, but for one shots like TV commercials, I always bottom lit. Things like perfume, beverages and some food. Also did a lot of black plastic shots. This is a rig to do what Chas is talking about. http://www.bogenimaging.us/Jahia/site/bius/pid/6780?kindOfProductCollectionRequest=productDetail&productCode=EL%2026266&productDescription=Transparent%20Plexiglas%20Plate%20For%20El%2019228%20Still%20Life%20Table&curBrandId=BEL&market=MKT1&product_from_search=true You could do this with some clear plexi, two saw horses and some white paper below (either flat or in a sweep).
Here is another way to light the product and the background separately. Look at this http://www.fullcompass.com/product/259188.html You poke a hole in your background and stick the Maxa-Mount through the hole and attach to C stand. Product is attached to flat on end. Product is framed so that it blocks the camera from seeing rod or just use PhotoShop to remove rod. Not all products will work with this. You can also home make something like this using tubing, pipe or all thread (all thread is metal rod with threads from one end to the other,your local hardware should have it).
Nov 25, 2008 at 03:56 AM
joesmosax
p.1 #7 · No Shadow White Backround Help - Product Shoot
Excellent. For what I'm doing bottom lighting seems to be the way to go. Thanks for the info.
Out of curiosity what are some good books on the subject of product lighting?
-Joe
Nov 25, 2008 at 04:09 AM
c.d.embrey
p.1 #8 · No Shadow White Backround Help - Product Shoot
<Chas>
Many people, beside Chas recommend Light: Science and Magic http://www.amazon.com/Light-Science-Introduction-Photographic-Lighting/dp/0240808193/ref=sr_1_10?ie=UTF8&s=books&qid=1227588937&sr=1-10 Looks good to me. Here's a quote of a readers review on Amazon 'This is the first book I have seen on photographic lighting that is worth using as a text. Light-Science and Magic is about principles, not cheap tricks or the authors' portfolio. Thanks.'---Pete Christman, Savannah College of Art and Design. Check-it-out.
When I learned to do this back in the Dark Ages, we did it by on-the-job training. Never read any books except the three book Ansel Adams series. The Camera 1, The Negative 2 and The Print 3. http://www.amazon.com/Camera-Ansel-Adams-Photography-Book/sim/0821221841/2/ref=pd_cp_b_sexpl
Nov 25, 2008 at 05:02 AM
cgardner
p.1 #9 · No Shadow White Backround Help - Product Shoot
Not sure how you are editing in Photoshop, but for products on a plain white background without shadows masking in Photoshop is a quick and easy solution which you could do with what you have. The mask features added to CS4 make masking much simpler.
All that is required is shooting the object in a way that doesn't create any shadows. Supporting it with rods or wires in space in front of a neutral background which contrasts with but doesn't reflect a color cast.
Good contrast between object and background makes selection of the background and mask creation simple: select the background with the magic wand, opt+click the mask icon in the layers window, then adjust the mask as needed to hide the support. Then you can insert a layer filled with any tone or color beneath the masked background layer.
The mask can also be used, inverted, filled with black and blurred, to create a uniform drop shadow for all the objects in a catalog. That step can be automated with an action.
This isn't to say the Photoshop option is better than the shooting options already mentioned, only to point out there are likely easier and more effect ways to do it in Photoshop than those you are using to achieve consistent backgrounds. The simplest way to get backgrounds 100% consistent shot-to-shot is via masking and creating the background numerically in Photoshop. 255.255.255 is not the ideal choice for a "white" background either. 255 represents pure light and should be reserved for specular reflections which are important for creating the illusion of 3D, especially in white objects. A "paper" white background with a value of around 250 will allow the specular highlights in your subject to contrast (e.g. rim lighting on towel in example below):
The thing to realize is that the brain will tune out the background immediately and think it is white even if it is a value less than 255. In fact the darker you make the background the brighter and whiter the things in the foreground will appear to be perceptually.
Nov 25, 2008 at 01:38 PM
