Archive 2008 · 50mm 1.4 vs 1.2 Stopped Down
Ben Horne
p.1 #1 · 50mm 1.4 vs 1.2 Stopped Down
Hi all, I'm just wondering if anyone has any experience with the 50mm 1.4 and 50mm 1.2 when stopped down to around f/16 or f/18. I am currently using a 50mm 1.4 for multi-row Panorama shots. I'm just curious if the 1.2 will give any better performance in this range. I realize they are being affected by diffraction at these apertures, but the test websites don't go beyond f/8 or f/11.
Nov 18, 2008 at 09:20 AM
photogenix
p.1 #2 · 50mm 1.4 vs 1.2 Stopped Down
P.S.: The 50 f1.2L only goes to f/16 .
Nov 18, 2008 at 09:25 AM
Ben Horne
p.1 #3 · 50mm 1.4 vs 1.2 Stopped Down
Good to know. Since that's the smallest aperture, I think that may very well answer the question...
Nov 18, 2008 at 09:40 AM
Beni
p.1 #4 · 50mm 1.4 vs 1.2 Stopped Down
What I did find is that I couldn't notice any difference between the 1.4 and the macro when stopped down to f16/22 which I didn't expect.
Nov 18, 2008 at 09:55 AM
tdodd
p.1 #5 · 50mm 1.4 vs 1.2 Stopped Down
f/16 compared here on a 1D3....
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=403&Camera=453&Sample=0&FLI=0&API=10&LensComp=115&CameraComp=453&SampleComp=0&FLIComp=0&APIComp=9
Nov 18, 2008 at 10:22 AM
dcmiller
p.1 #6 · 50mm 1.4 vs 1.2 Stopped Down
a 50/f2 macro would be mostly likely designed for sharpness at small apertures. Contax may have some slow macros in the 50 - 60mm range.
With diffraction on a dense sensor it may not make any difference.
If movements can be used, the TSE 45mm might be a way to more resolved detail.
Focus blending is another work around.
Nov 18, 2008 at 11:47 AM
Ben Horne
p.1 #7 · 50mm 1.4 vs 1.2 Stopped Down
I've tried the 45mm TS-E, but the CA was very problematic. That was actually my first lens of choice. The 50mm solved nearly all of the issues.... I'm just checking to see if there are any better options when stopped down. I'll have to compare it to the 50mm compact macro.
Nov 18, 2008 at 12:41 PM
cogitech
p.1 #8 · 50mm 1.4 vs 1.2 Stopped Down
I've used my 50/2.5 CM at f25 with professional quality (food packaging) results. A bit of sharpening was all that was needed.
Nov 18, 2008 at 12:56 PM
anthonygh
p.1 #9 · 50mm 1.4 vs 1.2 Stopped Down
You are probably stopping down too far for your needs F11 should do about 10 ft to infinity...
Nov 18, 2008 at 02:48 PM
cogitech
p.1 #10 · 50mm 1.4 vs 1.2 Stopped Down
At a subject distance of 6 inches?
Nov 18, 2008 at 05:16 PM
