Archive 2008 · anyone coverted cyz lens to a900 use
masimo
p.1 #1 · anyone coverted cyz lens to a900 use
I have a 50mm f1.4, 35-70mm f3.4 and 21mm distagon. Can these be used on the a900 via conversion to m42 or anything else? I saw a topic discussing the possibility in Sept timeframe but no definitive answers.
Anyone?
Thanks,
Mike
Nov 17, 2008 at 01:40 AM
Anden
p.1 #2 · anyone coverted cyz lens to a900 use
It would take a lot guts to convert the 21/2.8 distagon :-)
Nov 17, 2008 at 01:46 AM
edwardkaraa
p.1 #3 · anyone coverted cyz lens to a900 use
I remember that someone on this forum has stated that it would be physically possible to adapt C/Y lenses to Sony. However, no adapters are available at the moment AFAIK.
Nov 17, 2008 at 02:16 AM
douglasf13
p.1 #4 · anyone coverted cyz lens to a900 use
search "leica 60mm" over in the Sony dslr forum on dpreview, and you should find a thread where a gentleman gives detailed instructions on converting cuz and leica lenses to Sony.
Nov 17, 2008 at 04:18 AM
masimo
p.1 #5 · anyone coverted cyz lens to a900 use
What a goldmine. Thanks a lot.
Mike
Nov 17, 2008 at 05:36 AM
masimo
p.1 #6 · anyone coverted cyz lens to a900 use
Yeh that is the one I would have to think on the most. OTOH the current CY mount isn't all that useful either.
Mike
Nov 17, 2008 at 05:41 AM
Tariq Gibran
p.1 #7 · anyone coverted cyz lens to a900 use
Please let us know what you end up converting and how the conversion goes. I'm sure you probably know, but the older Minolta manual focus lenses, particularly the often talked about MC Rokkor X 58mm 1.2 is very easy to convert to Sony/Minolta A mount. The screw holes in an existing A mount line up exactly with the older manual focus Minolta mount.
Nov 17, 2008 at 08:15 AM
tc95
p.1 #8 · anyone coverted cyz lens to a900 use
Here is some stuff off ebay...
Leica to Sony Adapter.....
M42 confirmation Adapter....
Nikon F with confirmation Adapter...
I actually bought the Nikon F to Sony for an A700 that I have...I will let you know what I think about it....when it comes in....I have a Sigma SD14 that I converted to Nikon F and it works perfectly....so these adapters probably do the same....let me know if anyone tries the Leica or M42..
Tony C.
Nov 17, 2008 at 08:17 AM
Tariq Gibran
p.1 #9 · anyone coverted cyz lens to a900 use
Of course, the only problem with most adapters(not the M42 adapter though) is that they either do not allow infinity focus(Leica Adapter) or they contain an image degrading glass element. That's why you generally have to adapt the actual mount for Sony/Minolta A mount.
Nov 17, 2008 at 08:29 AM
masimo
p.1 #10 · anyone coverted cyz lens to a900 use
I will if I move forward on this project. I sold a 5D a couple of months ago because I had decided to keep only the Sigma DP1 and travel light for a while. But your and others enthusiasm is making me think of getting an A900 or the next model in the line up.
thanks,
Mike
Nov 18, 2008 at 01:31 AM
