Archive 2008 · Contax zoom question
giadinh
p.1 #1 · Contax zoom question
I just started using my 13 year old 28-85/3.3-4 with my 5D. I am pleased with the color saturation, sharpness. Is the 35-70 much better?
I have always wanted the 35-70 but never could afford one when they were made. By the time I could afford nice glass, only the 28-85 was available.
Nov 07, 2008 at 02:37 AM
edwardkaraa
p.1 #2 · Contax zoom question
I think the 35-70 is much better in the corners at some focal lengths and f/5.6. The 28-85 is sharper in the center even wide open. Actually I believe this zoom has been designed to be used mostly wide open. There is a nice comparison at 16-9.net.
Nov 07, 2008 at 04:03 AM
Lotusm50
p.1 #3 · Contax zoom question
No, it is not much better. The 2 lenses are comparable. The 28-85 has a wider range (not that it is stellar at 28mm), but over the 35-70mm range they are close. I don't think you would really gain anything overall by getting the 35-70. You might lose a little weight and size, however, if that is important.
Nov 07, 2008 at 04:04 AM
edwardkaraa
p.1 #4 · Contax zoom question
According to 16-9.net, at 35mm and f/5.6, the 35-70 outperforms the 28-85 in the corners quite clearly (8.3 vs. 6.8) while both get an outstanding 8.7 in the center.
At 50mm and f/5.6, the 35-70 is marginally better in both center (8.9 vs. 8.4) and in the corners (8.2 vs. 7.9).
At 70mm (81mm for the 28-85) and f/5.6, the 35-70 is better in the center (8.8 vs. 8.3) but is softer in the corners (7.2 vs. 7.6).
You can draw your own conclusions.
Nov 07, 2008 at 04:22 AM
giadinh
p.1 #5 · Contax zoom question
Thanks for the input everyone.
Nov 07, 2008 at 05:49 AM
Andi Dietrich
Account Locked
p.1 #6 · Contax zoom question
the 28-85 is parafocal, it can be used with AF confirm chips without problem, the shorter zoom is a bit of a hassel to focus.
Striclty landscape the 35-70 is a bit sharper in the corners and has less weight. For everyday photography, the 28-85 is IMO the better lens.
Nov 07, 2008 at 08:37 AM
slungu
p.1 #7 · Contax zoom question
Since I noticed that I use the 28mm more often than any other lens when on vacation, and second the 100mm, I was wondering if the 28-85 would not be a better lens for me than the 35-70 due to the greater range that it offers. I do not expect it to beat the 28mm prime, but I guess since I usually shoot at 5.6-8.0 I would expect it to be a great travel lens. Any of you using this lens that way ?
Regards, Stefan
Nov 07, 2008 at 12:16 PM
giadinh
p.1 #8 · Contax zoom question
Andi,
How would you suggest encoding the AF confirm chip (focal length & aperture)?
My experience with a chipped adapter is generally positive except for use with flash since the camera/flash see 50 mm focal length & 2.0 aperture.
Any help and input would be greatly appreciated.
Nov 07, 2008 at 03:49 PM
Andi Dietrich
Account Locked
p.1 #9 · Contax zoom question
I never used coded AF chips, I guess I would look out for a lens with a barrel deformation and a bit of CA to be able to correct these in DPP, maybe 24-105L at the wide end if this is possible. However this is only an idea no user experiance
Nov 08, 2008 at 03:23 PM
brainiac
Account Locked
p.1 #10 · Contax zoom question
giadinh wrote:
Andi,
When you buy the adaptor, ask the seller to set the eprom to your chosen focal length and aperture.
Nov 08, 2008 at 03:25 PM
Andi Dietrich
Account Locked
p.1 #11 · Contax zoom question
Regards, Stefan
I prefer primes for travel, the zoom is rather large, however if you prefer a zoom lens this will make for a wonderful travel lens, pictures have the zeiss look out of the body
Nov 08, 2008 at 03:27 PM
giadinh
p.1 #12 · Contax zoom question
Stefan,
I used this lens for my travel in my younger days with film. It is, of course, larger than the primes. However, I felt that the benefit of having one lens with close to prime quality of several focal lengths outweighed the size concern.
Richard,
Should I have it encoded to 28mm/3.3 or 85mm/4.0 ?
Thanks.
Nov 08, 2008 at 05:13 PM
brainiac
Account Locked
p.1 #13 · Contax zoom question
That's up to you. If you get it encoded to the focal length and aperture of a similar Canon lens, then sometimes that means you can use DPP's lens aberration settings, which may or may not be appropriate.
Nov 08, 2008 at 05:28 PM
