Archive 2008 · shutter count for 20d
munzir.khan
p.1 #1 · shutter count for 20d
please suggest and link the software which can count actuations for the Canon 20d...
Thanks
Oct 24, 2008 at 10:26 AM
kodakeos
p.1 #2 · shutter count for 20d
Canon XXD series have no shutter value software.
Apparently, the techs in Irvine or Jamesburg can pull it out of somewhere but no software readily available does it.
Oct 24, 2008 at 10:38 AM
munzir.khan
p.1 #3 · shutter count for 20d
ok... this means someone has to be honest if he is the second seller who himself doesn't know the actuations.... how you will sell this without knowing actuations.... ?
Oct 24, 2008 at 02:57 PM
Pandacat
p.1 #4 · shutter count for 20d
When I bought my 20D new, I never reset the picture folder counter. It would save pictures in groups of 100. If you have always used continous numbering, that would give you an idea. But if you or the other owner did not use continous numbering, then I don't know how you could tell. Not sure if it would be worth it to send it in to tech just for a shutter count.
Oct 24, 2008 at 03:21 PM
munzir.khan
p.1 #5 · shutter count for 20d
exactly... someone has to go for tech. to justify it.... prior to sell....
Canon should make an open exif.
Oct 24, 2008 at 03:44 PM
pixelman
p.1 #6 · shutter count for 20d
It's a moot point since they will fail at differnet rates anyways. Some last, some don't. I think most go with general appearance and you won't be too far off. Besides that body is cruising under $400 bucks now anyway.
Oct 24, 2008 at 10:46 PM
TeePee
p.1 #7 · shutter count for 20d
Hello:
You can read the shutter count in a RAW file with a Hex reader (Hexedit for mac. FI). Just open the file and go to adress 95D and 95E. Read the numbers xx xx in those adresses, and then translate them into decimal format (there are some translators on the web) and you will have the desired number.
Hope it helps
Oct 25, 2008 at 08:37 AM
Thats Fresh
p.1 #8 · shutter count for 20d
i might have to try it out. does it work for the 40/50D?
Oct 25, 2008 at 08:44 AM
TeePee
p.1 #9 · shutter count for 20d
I have not the slightest idea if it works for a 40D/50D, for those bodies try the software in here: http://answers.yahoo.com/question/index?qid=20080930104626AAFi5bl
Hope it helps.
TP
Oct 25, 2008 at 09:28 AM
munzir.khan
p.1 #10 · shutter count for 20d
Teepee... i will try out and let you know...
Oct 25, 2008 at 10:31 AM
kodakeos
p.1 #11 · shutter count for 20d
Wow - It worked on both 40D's I tried. (mine and my g/fs)
Hers has 38K shots - and the shutter failed
and Mine has 35K :/
Hope mine lasts longer than my g/f's
Oct 27, 2008 at 08:30 AM
bushwacker
p.1 #12 · shutter count for 20d
the 20D even when it set at "continous" it will reset its file numbering after 9999... I guess this is useless to depend on.
Jan 03, 2009 at 09:51 AM
RDKirk
p.1 #13 · shutter count for 20d
Excuse me, folks, but yes, please re-read this. The number of shutter cycles is practically irrelevant, much less important than overall condition of the camera.
I would especially look at the condition of the sensor (rather, the filter pack over the sensor) for signs of inept sensor cleaning. Really inept sensor cleaning can also damage the shutter, by the way.
Jan 03, 2009 at 10:29 AM
Milan Hutera
p.1 #14 · shutter count for 20d
The latest file on my camera reads 416-1693. Since the camera count starts at 100-0001 that means my camera took 31693 shots so far.
Jan 03, 2009 at 10:43 AM
jeskata
p.1 #15 · shutter count for 20d
TeePee wrote:
Hello:
Hope it helps
It reads all zeroes in a crw from 300D atleast.
Jan 03, 2009 at 12:03 PM
dcains
p.1 #16 · shutter count for 20d
This works for the 40/50D:
http://astrojargon.net/40dshuttercount.aspx?AspxAutoDetectCookieSupport=1
Jan 03, 2009 at 01:57 PM
