Moderated by: guardian
FM Forums | Alternative Gear & Lenses | Join Image Upload
Lotusm50
Image Upload: Off
p.1 #1 · Adapting Pentax K lens to Canon EOS
I know this was recently covered to some extent recently, but can't find that thread, so I want to focus this thread on an issue only suggested in that thread.
To adapt a Pentax K mount lens to Canon full frame, you need an adapter and to trim off the aperture control lever from the K lens mount. However, if you ever wanted to use the lens (particularly, an older one) on a future Pentax or Samsung DSLR (supposedly several in the works according to a Japanese investment analyst report) you are out of luck.
Instead (and hopefully I've got this right), how difficult is it to just open the lens mount and remove the aperture lever, and save it for later, just in case you might need it? I'm this is going to be different for different K-mount lens across different manufacturers, but should this be easily do-able?
Is there anyone who has done it? Any tips and/or advice for anyone tempting this? Thanks.
Oct 15, 2008 at 02:14 PM
Image Upload: On
p.1 #2 · Adapting Pentax K lens to Canon EOS
You don't have to remove the aperture control lever for a 1.6x CF body. You do have to remove it for a FF body. I'm not sure if you need to do it for a 1.3x CF body (but I can check at home tonight).
In this recent thread: http://www.fredmiranda.com/forum/topic/694185/0#6245645, mawz pointed out that -A and more recent lenses (with electronic contacts), were a problem with Pentax DSLR bodies, but earlier Pentax K-mount lenses (i.e. -M and "plain K" lenses) are still completely useful on Pentax DSLR.
It depends on the lens. On my SMC Pentax 18mm f/3.5, the aperture control lever is one continuous part (albeit, very bendy) all the way from the offending lever to the diaphragm itself. On this lens, removing the aperture lever would disable the diaphragm, so I cut it off.
Generally, it's not difficult to take off the mount ring and base cover (if the lens has one). Then you can have a closer look at the aperture control lever to see if it is a simple job to remove it (as it is on some lenses), or if it extends further into the lens body. In the latter case, you're on your own. I've opened and successfully closed many Pentax and third party K-mount lenses, right down to the aperture blades (and beyond), but there's a few in a drawer that weren't so easy to put back together. I'm confident that they could be reassembled by a repair pro, but that would cost more than getting another copy of the lenses in question.
Oct 15, 2008 at 03:39 PM
PhotoMaximum
Image Upload: Off
p.1 #3 · Adapting Pentax K lens to Canon EOS
Not to hijack the thread but how do you like the SMC Pentax 18mm f/3.5?
Oct 15, 2008 at 04:18 PM
Lotusm50
Image Upload: Off
p.1 #4 · Adapting Pentax K lens to Canon EOS
This would definitely be for a full frame Canon -- but would like to be able to keep my options open for the future. I'm still rooting for the underdog Pentax to come through with something spectacular. ;-)
PhotoMaximum
Image Upload: Off
p.1 #5 · Adapting Pentax K lens to Canon EOS
Which K lenses are you thinking about adapting?
Oct 15, 2008 at 04:24 PM
Lotusm50
Image Upload: Off
p.1 #6 · Adapting Pentax K lens to Canon EOS
a 55m f1.2
Oct 15, 2008 at 05:07 PM
PhotoMaximum
Image Upload: Off
p.1 #7 · Adapting Pentax K lens to Canon EOS
Nice...
Oct 15, 2008 at 05:47 PM
Image Upload: On
p.1 #8 · Adapting Pentax K lens to Canon EOS
Lotusm50 wrote:
a 55m f1.2
Either it's not a 55/1.2, or it's not a Pentax. What is it, a Tomioka?
Oct 15, 2008 at 10:46 PM
Lotusm50
Image Upload: Off
p.1 #9 · Adapting Pentax K lens to Canon EOS
Hmmm, could be.
Oct 16, 2008 at 01:19 AM
gtmerideth
Buy and Sell: On
p.1 #10 · Adapting Pentax K lens to Canon EOS
Lotus,
If you cut the lever and the guard you will still be able to use the lens on a Pentax body
but it will be fully manual. If you are interested in mounting a lens without cutting and
devaluation, Nikon AIS lenses can be mounted successfully on a 5D as they are.
There are a couple of informative posts on the net. Search Pentax lens to 5D.
gary merideth
Oct 16, 2008 at 02:15 AM
Lotusm50
Image Upload: Off
p.1 #11 · Adapting Pentax K lens to Canon EOS
I am aware of this, but am looking to see if i can b used and be reversible so it would function fully on a Pentax.
I currently have 5 manual focus Nikon AIS mount lenses that are used on a 5D so I am well aware of this. I was asking specifically about Pentax K mount lenses and how adapting them for use on a Canon full frame camera can be reversible.
Oct 16, 2008 at 02:51 AM
Lost password?
