David Clapp Offline Buy and Sell: On
p.1 #8 · Contax 21mm 2.8 after a couple of thousand exposures | |
jjlphoto wrote:
David Clapp wrote:
Well thats good to read Dave. I am currently going through testing the 1DsIII 14-24 and not havign as much fun as you are by the sounds of things..... I could write a very different review about it all right now from the glowing hype that surrounds the lens.
There was a report a while ago from another member who tested three samples of the 14~24 to get a good one. He mentioned quite a huge variance of IQ in his tests. (Apparently, Canon is not the only one with quality issues regarding sample variations.) Could you possibly have a dud?
I had my initial hire lens and then the one I purchased, both were the same.
There are many reasons as to why I bought it, I needed a wider field of view than 17mm for instance, but the majority of "wow isnt this lens the total mutts nutts" comments have had nothing to do with working method or landscape photography. Its got problems, setting hyperfocal distance accurately, IQ drop at f16 and even worse at f22, but the sharpness at f11, f8. 5.6 and even f4 is literally edge to edge and absolutely biting on my 1DsIII. On any wide angle this is unheard of agreed, but how often am I shooting a wide angle landscape at 18mm f8 for example? The foregrond is OOF. Even f11 is still not stopped down enough... if you have a look at my portfolio you can see the style I shoot, especially coastal work.
I am happy with it for what it is, but it is not the 'answer' like I hoped it would be. Its in another field of its own, a sidestep, but not a replacement for my 17-40, especially when at the sea. With all the stopping down, dark viewfinder, finnicky hyperfocal distance inaccuracy its a game as far as I can see. I couldnt imagine what would happen getting the front element belted with sea water.
Its all work in progress as far as I am concerned, anything with a querky working method takes a while to get used to, its just the f16 issue that is the biggest problem. Why lug a super heavy lens around in my bag if it performs no better than the lightweight 17-40 does at the aperture I use most?
I am going to write a full 'landscaping with the 14-24' review at some point after I feel fully in tune with it.
Edited on Oct 16, 2008 at 08:47 AM · View previous versions
