cogitech Offline Buy and Sell: On
p.1 #3 · TTL/ETTL Flash on Canon DSLR w/ Manual Focus Lenses? | |
Yes, I can confirm that it does work. I use it at weddings without issue. Well, sort of.
The only issues are:
1) The flash zoom function (as Michael stated), which I do not use anyway because I use bounce flash and/or flash stands w/umbrellas exclusively.
2) Metering is off (just like it is with manual lenses without flash) but I easily overcome that with FEC. Once set, it just works (even under changing lighting conditions).
For example: At a wedding I might stick my manual focus 28mm and my 550EX with a homemade "better bounce card" on my 5D. I set the camera to M, set a shutter speed of 1/60th or so, an appropriate ISO, set the lens to f5.6 or f8 and then scale focus it and leave the flash on full auto E-TTL mode. I fire a couple of shots, chimp and adjust FEC till I get a decent balance of flash and ambient (I might also tweak ISO during this process). Once I get the balance right (usually takes 3 or 4 quick shots) I then just walk around and capture the moments. This is a great setup for round-table and group shots during the reception.
I use the same method with longer lenses and faster apertures (for candids, etc.), but I focus by eye rather than by scale in those situations.
Another variation I use, which is very similar, is to use Av mode on the camera and then just keep an eye on the shutter speed. If it drops to low, I bump up the ISO accordingly. It is a bit easier to get a better balance of ambient and flash this way.
Edited on Oct 14, 2008 at 05:20 PM · View previous versions
