Archive 2008 · 5DII with Zeiss and CY Bellows
dezparker
p.1 #1 · 5DII with Zeiss and CY Bellows
I have the cy bellows system including the Zeiss 100 f4 lens.
I have had the system for several years but have only used it with Contax bodies.
The results are incredible and I want to keep all of my Zeiss lenses and the bellows system.
I plan to buy a 5dII when available...
Am worried if it will work with the cy bellows.
Also worried about my Zeiss 15mm 3.5
apparently there are mirror clearance problems with some lenses.
Anybody?
Oct 12, 2008 at 06:09 PM
shiwan
p.1 #2 · 5DII with Zeiss and CY Bellows
Stick your camera in Av mode and you're done. No AF confirm, though. As for the lenses themselves, that depends on which batch the camera comes from, etc. You can shave the mirror, or shave the lens shrouds, etc.
Oct 13, 2008 at 10:17 PM
dezparker
p.1 #3 · 5DII with Zeiss and CY Bellows
Thanks for the reply.
Are the variances between canon bodies of the same model that inconsistent?
Sounds like a bit of a crap shoot.
Oct 17, 2008 at 10:23 AM
Daniel Heineck
p.1 #4 · 5DII with Zeiss and CY Bellows
Bellows will have absolutely no problems, unless I have missed some lenses which extend WAY back into the bellows. Trying to hit infinity on some lenses may cause problems. (and are well documented), but I fail to remember a single case of anyone having problems at macro focusing distances on any lens. I suppose some floating element-style lenses could have problems if the rear element remains parked, but still, I don't remember a case of anyone having any issues with mounting macros.
Good luck and happy shooting,
Daniel
Oct 17, 2008 at 12:18 PM
Steve Spencer
p.1 #5 · 5DII with Zeiss and CY Bellows
Hi,
Here is a great database that should tell you about a lot of Contax/Zeiss lenses. The 5D and 5D II are likely to have similar issues, but we won't know for sure until the 5D II has been out for awhile.
http://www.pebbleplace.com/Personal/Contax_db.html
Oct 17, 2008 at 12:22 PM
jamesdak
p.1 #6 · 5DII with Zeiss and CY Bellows
Another concern may be if the bellows will clear the prism area. I use a Contax Bellows on my 5D with no problem but on some of the other EOS bodies the camera cannot properly lock onto the bellows because the prism box hits the rear of the bellows assembly.
Oct 17, 2008 at 12:35 PM
