mcbroomf Offline Image Upload: On
p.1 #4 · Canon 90mm tilt lens - how to use? | |
If you can post a photo or a link to one that shows the kind of problem you're having it will help us diagnose it. The shorter TS lenses can get fairly extreme foreground/background ranges in focus, the 90mm less so. However it also possible to over tilt. You really should be able to see what's happening as you tilt through the viewfinder, ie if you're over tilting you should see the foreground go through good focus to OOF, but if the lens can't be tilted far enough you'll see it get better but not completely in focus. By the way I prefer to focus on the middle distance, or even middle/foregound before I start tilting.
Mike
