cgardner Offline Image Upload: Off
p.1 #11 · Canon xsi vs 5D resolution | |
Sensor sizes have a profound effect on DOF. The smaller the sensor, the more DOF you get at a given f/stop. The reason is related to the fact f/stop numbers are based on the ratio between the focal length of the lens and the physical diameter of the aperture. WIth a smaller sensor a shorter actual focal length provides the same view angle (e.g. 10mm on a 1.6 crop has the same field of view as a 16mm on a FF sensor body). So if you compare DOF at f/4 of an 1/2" sensor all-in-one, 1.6, 1.3 and FF DSLR it will become progressively shallower, respectively.
Between FF 35mm film and my 1.6 crop 20D I used a small sensor Minolta D7Hi. It was a very nice little camera in many respects, but even wide open at f/3.5 it had almost infinite DOF. For example this shot was taken at f/3.5:
When I got my 20D the biggest adjustment was needing to pay more attention to focus point. but selective focus became a creative option again
Megapixels are not all there is to IQ. Sensor cell sizes affect the signal/noise ratio so a FF with larger sensor cells may have better overall IQ, especially in the shadows, than a smaller, higher MP sensor with smaller sensor cells because larger cells have higher S/N ratios (i.e. less noise).
I'm currently debating the merits of upgrading to a 5DmkII or staying with the 1.6 format with the 50D. Both have pros and cons for my needs, but the HD Video of the 5DMkII may tip the balance it its favor since I don't have a digital video camera.
