Macro World Resource
FM Forums | Macro & Still Life | Join Upload & Sell
Archive 2008 · Dung Flies
Adrian Jones
p.1 #1 · Dung Flies
A few Dung Fly shots from today.
Canon 20D + MP-E 65 + 580EX with milk bottle diffuser.
ISO 100, 1/250, f11.
All full frame uncropped images.
C&C welcomed as usual.
Adrian
Oct 03, 2008 at 02:50 PM
Eyvind Ness
p.1 #2 · Dung Flies
Ooo, very nice Dungs, indeed! I love the two last shots Wonderful lighting and detail on all these shots
Oct 03, 2008 at 02:57 PM
matuka
p.1 #3 · Dung Flies
Great shots Adrian
That MP-E 65 seems to be a great lens. I've been told that rookies like me should stay away from it. Is it really that hard shooting with this lens? I'm seeing the most amazing pictures taken with this lens all over this forum.
Oct 03, 2008 at 02:58 PM
DamonBarnett
p.1 #4 · Dung Flies
nice warm colors and detail
yah I regret now taking advice here and getting 100mm. I should have got the mpe to start with. too often I can't get close enough. Oh well.
Oct 03, 2008 at 03:13 PM
Adrian Jones
p.1 #5 · Dung Flies
Thank you Eyvind, much appreciated.
Adrian
Oct 03, 2008 at 03:17 PM
Matt OHarver
p.1 #6 · Dung Flies
Can I assume that everyone that uses this lens at that magnification uses a tripod? Thats some amazing colors focus and detail found in that lens.
Matt
Oct 03, 2008 at 04:02 PM
Adrian Jones
p.1 #7 · Dung Flies
matuka wrote:
Great shots Adrian
Hi Matuka, The MP-E is a truly superb lens in all respects. I think much would depend on the individual involved as to whether or not to buy this lens especially if they were new to macro, there is much to learn in using it but its well worth the effort.
I personally started with Canons 100mm macro and a set of Kenko extension tubes which gives a magnification up to 2x, the combination worked very well and it helped me a great deal in learning about focus and exposure at close range. It was however only about six months later that I decided to buy the MP-E and I never looked back, its my main lens now and the 100mm is now used for shots less than life size.
As well as the MP-E you would also need some form of flash, I use a single 580EX diffused with the bottom of a plastic milk bottle but also have Canons excellent MR 14 EX ringflash.
When the MP-E 65 is used at lower magnifications i.e. up to 2x, I personally think its easier to use than a 100mm macro plus a set of extension tubes, its at the higher magnifications that it becomes more of a beast to control, if you can get to a friendly Canon dealer try to get a hands on demo with your camera and the lens, it would at least show you some of the quirks of the lens that may help you decide if its for you at this time. Personally I would say if its within your budget and you are sure that a dedicated macro lens would get plenty of use (remember that the MP-E has no infinity focus and can only be used for shooting in the 1x - 5x range) then go for it, once mastered it will reward you well.
Adrian
Oct 03, 2008 at 04:05 PM
Adrian Jones
p.1 #8 · Dung Flies
Thanks packrobottom, appreciated.
Have you tried adding a set of extension tubes with the 100mm, the Kenko ones would let you get to just over 2x relatively cheaply.
Adrian
Edited on Oct 03, 2008 at 04:19 PM · View previous versions
Oct 03, 2008 at 04:07 PM
Adrian Jones
p.1 #9 · Dung Flies
Matt
Hi Matt, for insect shots most people here hand hold the camera, the short duration of the flash is usually enough to stop any motion blur, a tripod would be simply too slow and cumbersome to use.
Adrian
Oct 03, 2008 at 04:13 PM
matuka
p.1 #10 · Dung Flies
Thanks for the reply Adrian! I know there will be some trouble mastering this lens, but the results are awesome. I'll see if I can try one out for some time.
At the moment I'm using the same set-up you used to have: the 100 mm + tubes and a MR 14 EX ringlite. Putting the tubes on makes focusing a bit difficult, everything gets quite dark. How does that work with the MP-E? Is it 2.8 at all magnifications? If so, that should be great.
Oct 03, 2008 at 04:24 PM
Tim Dollear
p.1 #11 · Dung Flies
very nice series. Good question on the aperture on the MPE-65, btw.
Oct 03, 2008 at 04:39 PM
Adrian Jones
p.1 #12 · Dung Flies
Basically the MP-E is a lens with built in variable extension tubes and the viewfinder does darken considerably as magnification increases.
Now I hope I get this right, I'm no expert when it comes to the technical side of things but as far as I know the MP-E is always wide open whilst focusing whatever the magnification but the effective aperture does change as the magnification increases and the distance to the subject decreases, hence at 1x an indicated f2.8 is effectively f5.6, at 5x with an indicated f2.8 the effective aperture is f16.8 hence the darkening in the viewfinder.
If I have made any incorrect assumptions above hopefully someone will soon correct me.
Adrian
Oct 03, 2008 at 05:11 PM
Adrian Jones
p.1 #13 · Dung Flies
Thanks Tim, appreciated, hope I got the info on effective aperture correct in my reply above!
Adrian
Oct 03, 2008 at 05:13 PM
michael kilner
p.1 #14 · Dung Flies
great shots Adrian esp the last
Oct 03, 2008 at 05:19 PM
LordV
p.1 #15 · Dung Flies
Excellent series
Brian V.
Oct 04, 2008 at 12:28 AM
Eyvind Ness
p.1 #16 · Dung Flies
Adrian
You did, Adrian! It's in the manual, effeective f = f x (magnification + 1)
so, f2.8 at 5x = 2.8 x (5 + 1) = f16.8
Also, in the manual the DOF table for different magnifications and f-number:
At 5x, the DOF is 0.095mm at f5.6, and 0.134mm at f8 (!) Any higher, and the Diffraction Troll will eat your shots alive.
Ref. Brian's excellent diffraction post here:
https://www.fredmiranda.com/forum/topic/684385
And BTW: No responsible person will ever recommend the MP-E as a first macro lens, for good reasons. And buying one, thinking you'll automatically have pictures like these produced here by Adrian is a fairly naive idea, to put it politely
Oct 04, 2008 at 03:37 AM
Pixel Perfect
p.1 #17 · Dung Flies
Beautifully diffused lighting and superb shots.
Oct 04, 2008 at 07:02 AM
matuka
p.1 #18 · Dung Flies
Thanks a lot Adrian for the information. Not exactly what I wanted to hear, but hey, nothing is as easy as it looks. I'll see what I will do. Before even considering buying one I'll try one out at my Canon-dealer. Thanks again.
Thanks for the remark Eyvind. Sounds like good advice to me And I can assure you: I don't think it's easy at all. I'm having enough trouble right now when I put all the tubes on.
Oct 04, 2008 at 08:17 AM
Adrian Jones
p.1 #19 · Dung Flies
Thanks Michael, much appreciated.
Adrian
Oct 04, 2008 at 10:29 AM
Adrian Jones
p.1 #20 · Dung Flies
LordV wrote:
Excellent series
Brian V.
Thank you Brian, much appreciated.
Adrian
Oct 04, 2008 at 10:30 AM
