Moderated by: guardian
FM Forums | General Gear-talk | Join Image Upload
mufutau
Image Upload: Off
p.1 #1 · External USB Hard Drives Enclosure
I am in need of good USB 2.0 External Hard drives enclosure for 2 to 4 hard drives that can accommodate 1TB of drive each. What is the best to buy for reasonale amount that won't break my wallet/bank. And what 500GB to 1TB drive will you recommend for this enclosure. The links to the products will be highly appreciated.
Thank you.
Mufutau
Edited on Oct 03, 2008 at 03:18 AM · View previous versions
Oct 03, 2008 at 01:16 AM
Edgar Maguyon
Buy and Sell: On
p.1 #2 · External USB Hard Drives Enclosure
Thermaltake BlacX w/ esata.
Got one and love it.
If you have extra $$, maybe the Drobo.
Oct 03, 2008 at 02:50 AM
Rockies Photo
Image Upload: Off
p.1 #3 · External USB Hard Drives Enclosure
Mufutau,
I just bought (2) 1TB Seagate 7200.11 HDD's, to run in a Raid 1 configuration, to back up all my important images & files.
HDD Link Here
This is the enclosure, I also bought. It only works in a Raid 1 Config, but man is it quiet, and FAST, as it has FW800/400, & USB 2.0 Connections. I use the FW800 myself.
Link Here
This is another enclosure, that may work for your needs. It is configurable as either Raid 0 or JBOD. And has FW800/400 & USB 2.0 too.
Link Here
Both enclosures' accept 1TB no problem at all.
I'm not sure any enclosure will handle 500MB HDD's, If you can still find them.
Good Luck,
James
Oct 03, 2008 at 03:01 AM
mufutau
Image Upload: Off
p.1 #4 · External USB Hard Drives Enclosure
Thanks for the suggestions and links. I will explore them. On the Hard drive, I meant 500GB not 500MB, that was a typo. I have edited my earlier message to reflect that. Thanks.
Mufutau
Rockies Photo wrote:
Mufutau,
HDD Link Here
Link Here
Link Here
Good Luck,
James
Oct 03, 2008 at 03:20 AM
mufutau
Image Upload: Off
p.1 #5 · External USB Hard Drives Enclosure
Thanks. I will do a search for this.
Mufutau
Oct 03, 2008 at 03:26 AM
invalid2
Image Upload: Off
p.1 #6 · External USB Hard Drives Enclosure
Thank you.
Do you really want USB? Do you want the drives to show up individually?
I would think a port multiplier capable esata card+enclosure would be something to check out.
One example of a sata enclosure is this, which is $44/drive. A USB enclosure is this, at $70/drive. Individual enclosures, like this at $14/drive are quite cheap as well. Not fun to stack or power, but functional.
Oct 03, 2008 at 04:46 AM
mufutau
Image Upload: Off
p.1 #7 · External USB Hard Drives Enclosure
Thanks Invalid2. The only option I have is the USB 2.0 connection. I have an HP Pavilion Elite m9250f, there are no more drive bays left in the system, no more option to install external Sata card in the system.. so I have to go the USB 2.0 route. Thank you for all the links, if everything else fails, I will just get the single drive enclosure like the one you linked for $13.99, it may server its purpose because I need to configure the drives as individual drives anyway. There are so many of this external enclosure around, I just want to get a good one. Thanks again.
Mufutau
invalid2 wrote:
Thank you.
Oct 03, 2008 at 06:22 PM
Lost password?
