Rockies Photo Offline Image Upload: Off
p.1 #7 · Best Bag for 2 bodies and . . . | |
I'm not sure if they are made to do it, but the Think Tank Modulus Set, may be an answer. I recently purchased the 6 pc Set, Belt & the Pixel Racing Harness. It is an excellent means of getting gear from point A to B, w/o using backpacks/rollers/shoulder bags. I decided which pieces I need before I head out, and that is what I use, while I'm shooting.
To solve your question, I would recommend the Belt, Harness, & maybe just buy a couple LC75's. They hold my 100-400 w/ hood mounted, as a standard carry system. However, I have also walked around quite a bit, with one of my 1D2N's fixed to the 100-400, and not had anything that would be construed as too much/ extra weight hanging off the belt. The shoulder harness, does an excellent job of weight distribution.
The LC75 will easily hold any of the following: 300/4, 100-400, 70-200/4 or 2.8, & probably 400/5.6 too... The LC35 will hold the 24-70 w/ hood attached. I currently have my 70-200 2.8 w/ hood reversed in the LC35...
Hope this suggestion helps.
James
