pascal03 Offline Upload & Sell: Off
p.1 #8 · Olympus 14-35 mm f 2.0 | |
I disagree on some of the opinions. As much as I really like the Olympus system, I admit the current Olympus sensor is not the best for everything. I use a D300 & SLRn, 5D, SLRc, & 30D, and E3's, e330, and other Olympus SLR's.
If you use all three systems side by side, you begin to notice what is good and bad about each and then eventually figure out which system is suited best for your needs. Neither Canon nor Nikon are perfect. Along the same lines, Olympus isn't perfect either. However, each one has it's strengths depending on what you shoot and under what conditions.
Also, it's pointless to compare an e420 or e410 to the 5D just as it's useless to compare a rebel XSi to a D700 or a Nikon D40 to the 5D. If we are to level the playing field with SLR's, lets compare the D300 to the 5D to the E3.
To me, the D300 is a better SLR than the E3 and the E3 is a better body than the 5D. If you want to discuss image quality, then it would go D3, 5D, D300 - then again "image quality" can mean different things to different photographers.
The E3+7-14mm f4.0 is an amazing combination. The only way to get similar results is spending $3000 for the D700 + $1600 for the 14-24mm f2.8. The E3 can be had for $1500 and the 7-14mm f4.0 is $1500 which is about the cost of the D700.
If you want to leave the cost out and focus just on what each system and lenses can provide, Olympus still can hold it's ground under certain circumstances.
As far as image quality (this is personal opinion as each person has different taste), if you look for color and sharpness, Olympus can easily provide the sharpest images I have seen from all three systems. The Canon 5D is the next best thing.
Not sure if this has to do with a low strength AA filter or uber-sharp lenses or a combination of the two. In terms of sharp images, Olympus wins, followed by Canon, and finally by Nikon. Nikon images just don't have the sharpness unless you work on it in post processing. Canon images are sharp depending on which lens you use and there is some visible variation here.
The SLRn, which lacks an AA filter, can provide sharper images than the D700 and the D300, but most nikon lenses are not in the same league as the olympus pro grade lenses unless you go for the pricey 24-70mm f2.8 or the 14-24mm f2.8.
The overall look.... which includes the color (and I mean eye popping color) - I like what I get from both Olympus and Nikon. Canon lags behind for my tastes. You can eventually get there with Canon, but it takes a little post processing work.
Given this, I am sure each photographer has his/her own priorities and preferences. For some, RAW is simply not an option. For others, JPG's exist only for a quick preview and the RAW files are perfected to their tastes. Again, boils down to what you use each system for and how.
I use Canon for landscapes and architecture
Nikon for general indoors (that Nikon flash system is simply exquisite)
I use Olympus for nature/wildlife and general shooting. That 2x FOV factor is sweet when it comes to birding/sports.
Canon and Nikon have the upper hand when it comes to lower noise at high ISO. There is no doubt there. When it comes to dynamic range, Nikon is very good. The 5D and E3 almost at a tie.
Now if Canon or Nikon were to introduce a 14-35mm f2.0 or 35-100mm f2.0 lens that was usable on the 50D or the 5D, how many would jump at it
Edited by pascal03 on Sep 09, 2008 at 03:22 AM GMT
Edited on Sep 08, 2008 at 10:22 PM
