FM Forums | Forum & miscellaneous | Join Image Upload
pawlowski6132
Image Upload: On
p.1 #1 · Frame Building
Anyone build their own picture frames? I'd like to try this with some advice, direction, maybe instructions, etc.
Any advice?
Edited on Sep 05, 2008 at 07:31 PM
J4644
Image Upload: Off
p.1 #2 · Frame Building
Hi Joe,
I do some custom woodworking. First off, I have to ask you why you want to bother making your own frames? The reason I ask, is that it is a lot of work and generally more expensive than buying them. In fact, I wait until they are on sale at Michaels or any other craft store. Example, just bought (10) 10 x 13 inch frames for under $54.00, tax included. You can place a 11 x 8 inch photo in them with a 1 inch matt all around. To make that frame I would bet that the materials alone would be much more than that, and that does not include your time.
On the other hand, if you tell me that you want a custom size or custom look or you enjoy the time spent in making something with your own hands, then that is a different story. Then I have to ask you do you intend on buying your wood in the rough? In this state, it is very rough and needs to be machined flat and square. In order to do this properly you need some nice tools. Number one is a good tablesaw. If rough stock is what you will be starting with, then number two is a good jointer. Three would be a planer. Four would be a router, preferable with a router table and obviously some bits to cut your profiles.
If you buy made up stock, you would not need as much equipment. However, made up stock is more expensive and sometimes the stock is not flat or square which will make your mitre joints more difficult to get right.
Let me know what your intentions are and I will be more than happy to give you some further advice.
Thanks,
Jim
Edited by J4644 on Sep 07, 2008 at 04:58 PM GMT
Edited on Sep 07, 2008 at 04:58 PM
Sep 06, 2008 at 01:31 PM
dcains
Buy and Sell: On
p.1 #3 · Frame Building
Here's a nice article on matting:
CLICK
Sep 06, 2008 at 04:14 PM
pawlowski6132
Image Upload: On
p.1 #4 · Frame Building
Hi Jim. Actually, I did think it would be cheaper to build my own. But it actually sounds like it'd be a pain in the butt and require lots of patience.
I'm really bad at that type of stuff (think Homer Simpson projects) and don't have any tools.
I don't know what the hell I was thinking. Oh well.
Can you build me a frame
Thanx!
Sep 08, 2008 at 08:53 PM
J4644
Image Upload: Off
p.1 #5 · Frame Building
Hi Joe,
I did not mean to discourage you. However, like photography or anything else for that matter, to do things well it takes some time and money. If you do not have any tools at this point, then you have a considerable investment to make. I would suggest that you take that money and buy some lenses with it. You can always buy the frames relatively cheaply.
As for making you a frame, I would do that for you. However, the frame would have to be something that you could not find on a shelf anywhere else, hence the need to have it custom made. As a result it would also be relatively expensive. So, if you can find what you want at a store, then you should just buy it.
By the way, I thought your thread on better PP for the images of your dog was a very good one. I hope you finally got the image you wanted.
Jim
Sep 08, 2008 at 10:16 PM
Lost password?
