Moderated by: guardian
Archive 2008 · flogging a dead horse Go to previous topic Go to next topic
digitalbug30d
Image Upload: Off
p.1 #1 · flogging a dead horse
Is there anyone that can answer this simple yet complex question
what is the best ISO in regards to sensor output/dynamic range
I shoot ASA 200(old school) is 100 better...?
Aug 31, 2008 at 02:18 AM
EB-1
Image Upload: Off
p.1 #2 · flogging a dead horse
Typically the native ISO of the sensor is best because the S/N is higher. That is usually the lowest normally accessible ISO setting, i.e., not an expanded low or high setting. However, some cameras are known to "pull" the lowest ISOs, in which case a slightly higher ISO would be better. Also, some sensors do not employ 1/3-stop variable amplification across the ISO range, so the full-stop ISO settings (100, 200, 400, etc.) are desirable.
Which camera do you use?
Aug 31, 2008 at 02:36 AM
digitalbug30d
Image Upload: Off
p.1 #3 · flogging a dead horse
30D
Aug 31, 2008 at 02:59 AM
Gary Petersen
Image Upload: On
p.1 #4 · flogging a dead horse
It mattered a bit more on my 20D where I would use the lowest ISO I could get away with.
Aug 31, 2008 at 03:13 AM
nathanlake
Image Upload: On
p.1 #5 · flogging a dead horse
Sensors don't have a single native ISO. The gain on the sensor is turned up and down for most ISO settings. The assumption is that turning the gain all the way down (ISO 100 in most cases) would give you the best result, but there was a pretty good test done some time last year on the 1DMIII that showed ISO 200 might give a better result.
ISO 50 (or L) is the gain turned all the way down plus some firmware magic. It is that magic that causes you to lose some dynamic range at ISO 50 on most Canon cameras. I have no idea about Nikon.
Edited on Aug 31, 2008 at 03:27 AM
Aug 31, 2008 at 03:26 AM
trumpet_guy
Image Upload: On
p.1 #6 · flogging a dead horse
My experience with the 30D and the XT suggests that ISO 100 is
best for low noise and high dynamic range. I could believe that ISO 200
would be better for some sensors, though. You'd have to check on a
model by model basis.
Aug 31, 2008 at 07:42 AM
mihind24
Image Upload: On
p.1 #7 · flogging a dead horse
I've heard ISO 200 is best on a 40D, someone did tests apparently? Of course I may be wrong, or that person's test may have been flawed. Haven't tested it myself. How would you test it? I wouldn't know where to begin.
Aug 31, 2008 at 08:27 AM
Alan321
Image Upload: On
p.1 #8 · flogging a dead horse
I expect the difference between ISO 100 and 200 will be minimal. However, it might have been Emil (ejmartin) who did some comprehensive analyses and published them a while back. I'll have to look for the link.
- Alan
Aug 31, 2008 at 10:23 AM
Alan321
Image Upload: On
p.1 #9 · flogging a dead horse
Here you go. Look at this test for the 30D - but if you cannot stand the technical stuff then the answer you're after is ISO 100. Or 200 The dynamic range is slightly greater at ISO 200 but so is the "dark noise", which means that despite the additional DR there is still more noise in the shadows.
http://www.pages.drexel.edu/~par24/rawhistogram/30DTest.html
Of course, if you shoot jpeg instead of raw then you've discarded much of the useful DR anyway and it won't matter so much which ISO you use.
I haven't found the link to Emil's stuff yet. It's probably staring at me from the screen but I've lost it. Still, it had some very complex and detailed work along with some interesting and understandable conclusions. I'll look again.
- Alan
Aug 31, 2008 at 10:47 AM
Lost password?
