Archive 2008 · Opinions on issue - thanx in advance
John Ferguson
p.1 #1 · Opinions on issue - thanx in advance
Is it time for a new shutter?
Edited on Aug 30, 2008 at 05:44 AM
Aug 30, 2008 at 05:43 AM
EltonTeng
p.1 #2 · Opinions on issue - thanx in advance
Is this straight from the camera, or after the raw converter?
Note: I was testing Capture One 4 the other day and one of my images that opens fine in DPP & Silkypix looks just like one of these in Capture One. Strangest thing.
Edited by EltonTeng on Aug 29, 2008 at 09:58 PM GMT
Edited by EltonTeng on Aug 29, 2008 at 09:59 PM GMT
Edited on Aug 30, 2008 at 05:59 AM
Aug 30, 2008 at 05:47 AM
princeeric2
p.1 #3 · Opinions on issue - thanx in advance
I have seen some earlier posts with this similar problem, it suggested a sensor problem rather than a shutter problem. Let see what other's opinions are.
Edited by princeeric2 on Aug 29, 2008 at 11:49 PM GMT
Edited on Aug 30, 2008 at 05:49 AM
Aug 30, 2008 at 05:48 AM
Spyro P.
p.1 #4 · Opinions on issue - thanx in advance
No its not the shutter, I think this is either a borked cf card or sensor
mpmendenhall
p.1 #5 · Opinions on issue - thanx in advance
Those don't look like shutter problems. A shutter problem would result in black/darkened bars uniform across the entire width of the image, not weird color problems in quarters of the image. Your camera is probably mechanically fine --- the problem appears to be on the digital side.
Aug 30, 2008 at 05:50 AM
Gary Petersen
p.1 #6 · Opinions on issue - thanx in advance
I agree with Spyro. Either the card or the sensor itself.
Aug 30, 2008 at 05:55 AM
John Ferguson
p.1 #7 · Opinions on issue - thanx in advance
Was a raw converter issue, thanks for asking.
Whoops ... not a raw converter issue. The .jpg straight from the camera looks fine but the RAW does this with three different converters. Maybe it is the card ...
Edited on Aug 30, 2008 at 06:04 AM
Aug 30, 2008 at 05:57 AM
Gary Petersen
p.1 #8 · Opinions on issue - thanx in advance
New one on me. Which RAW converter?
rhorta
p.1 #9 · Opinions on issue - thanx in advance
Last time IIRC it was faulty memory, not the shutter.
Doesn't make sense that the camera can process internally to JPEG, but cannot produce a native RAW file.
Format the memory card?
Try another memory card?
Reset the camera to default?
Remove all batteries from camera?
Reinstall the firmware?
Use Canon DPP?
Ruy
Edited on Aug 30, 2008 at 07:29 AM
Aug 30, 2008 at 07:28 AM
darryn patch
p.1 #10 · Opinions on issue - thanx in advance
I've seen that when you fire a sequence and you turn the camera off before it finishes writing to the card.
Definatly a card problem.
What brand of card are you using?? and where did you buy it from??
Aug 30, 2008 at 09:41 AM
Emile Gregoire
p.1 #11 · Opinions on issue - thanx in advance
My thought exactly, so I'd guess it's a card issue.
Aug 30, 2008 at 10:35 AM
gbee
p.1 #12 · Opinions on issue - thanx in advance
It's more likely a card reader issue.
Sometimes updated drivers will curse this, more often it's the reader itself.
I've seen the occasional file similar to this from all my cameras, but once or twice it became a regular experience and dumping the reader fixed the problems.
It can be frustrating as from one camera, same card same reader it may be fine, another camera, not so, thus leading to one suspecting the camera ~~ whilst the camera can be responsible for this on very rare occasions, it's usually the actual card reader itself.
Extra: BTW, if your files are still on the original card, they should transfer just fine with a new reader ...
Edited on Aug 30, 2008 at 11:15 AM
Aug 30, 2008 at 11:13 AM
John Mills
p.1 #13 · Opinions on issue - thanx in advance
What brand of card is it? I had a 1gig no name brand that did the same thing. So I changed to Extreme III's and have never lost an image since.
Aug 30, 2008 at 12:18 PM
John Ferguson
p.1 #14 · Opinions on issue - thanx in advance
Sandisk Extreme III 16 gig purchased at Amazon IIRC. Will try a different card reader, files are still on the card. Canon DPP conversion looks bad too. Thanks for the suggestions.
Aug 30, 2008 at 08:28 PM
Beni
p.1 #15 · Opinions on issue - thanx in advance
Only time I ever had this it was the card.
Aug 30, 2008 at 08:35 PM
dcains
p.1 #16 · Opinions on issue - thanx in advance
Absolutely a memory issue of some sort, either the card itself, or card reader.
Aug 31, 2008 at 12:11 PM
orangefirefish
p.1 #17 · Opinions on issue - thanx in advance
That doesn't look like a shutter issue- a shutter issue would be indicated by some portion of the image being black. Your sensor may be the issue (although it doesn't look like it because there's no distinct pattern in the corruption of the images). Something is getting lost in translation, either the A/D converter isn't encoding properly, the processor isn't handling your image correctly, or your card writer is malfunctioning.
Aug 31, 2008 at 12:21 PM
