Archive 2008 · 1D sync at 1/1000th???
SKYWESTR
p.1 #1 · 1D sync at 1/1000th???
So I got me some Cybersyncs and low and behold, they sync to 1/1000th on the 1D. I thought the 1D could only sync to 1/500th (and does limit itself to that when the flash is in the hotshoe), but I've seen no degradation right up to 1/1000th. At 1/1600th the entire image gets a bit darker and at 1/2000 it's totally black though.
I tried it on my 20d and it'll go to 1/320th with no ill effects (up from 1/250), any more and the black line creeps in. Just wondering if anyone normally syncs to this when shooting with Cybersyncs and if it can be done with PWs. Here's a sample shot from the 1D.
Carl
  Canon EOS-1D    85 mm    f/4.0    1/1000 sec    200 ISO    0.0 EV
Aug 29, 2008 at 11:43 PM
Rockies Photo
p.1 #2 · 1D sync at 1/1000th???
That is one colorful LCD. Do you do product shooting for Viewsonic?
Aug 30, 2008 at 12:35 AM
robstein
p.1 #3 · 1D sync at 1/1000th???
There is a post over on the AB thread where he is syncing at 1/2500 (although at that speed you are starting to cut into the flash exposure time, so not getting all of the light). I use the 20D as 1/320 with no issue like you and I suspect they put some buffer on the speed it can sync at.... although apparently the 5D is not one of those with a buffer. Not sure about the others.
Edited on Aug 30, 2008 at 12:42 AM
Will Patterson
p.1 #4 · 1D sync at 1/1000th???
I have that monitor in the 20" size, great LCD for the money
Aug 30, 2008 at 12:48 AM
SKYWESTR
p.1 #5 · 1D sync at 1/1000th???
I just picked that monitor up and the box it came in was the only thing I could think of to shoot that had a good representation of white and color. Looking at it again, I guess it does look a bit like an ad.....just a pic of a box though.
Carl
Aug 30, 2008 at 01:15 AM
Ariel Bravy
p.1 #6 · 1D sync at 1/1000th???
I did a similar test and with an off-shoe hotshoe cable, I was able to get it to reliably sync at 1/2500, and occasionally 1/3200 while other times it went somewhat dark. Here's the link.
http://www.fredmiranda.com/forum/topic/662846/#5911138
It sounds like the sync speed limitation you found is in the Cybersyncs themselves not being able to sync faster than 1/1000 reliably... not that there's anything wrong with that.
Out of curiosity, what happens when you shoot at ISO 3200 with a fast lens wide open and a full flash pop when shooting at 1/2000 or faster? Do you get an image visible or is it still totally black?
Edited on Aug 30, 2008 at 04:06 AM
Aug 30, 2008 at 04:04 AM
SKYWESTR
p.1 #7 · 1D sync at 1/1000th???
I was hoping you'd chime in Ariel
I went right up to 1/16,000 and it was nearly the same as 1/2,500 at ISO 3200. both purple. sample pic at 1/16000 still though, pretty cool it can be done.
carl
edit reason:can't spell....
  Canon EOS-1D    85 mm    f/2.0    1/16000 sec    3200 ISO    0.0 EV
Edited on Aug 30, 2008 at 06:42 AM
Aug 30, 2008 at 06:41 AM
Ariel Bravy
p.1 #8 · 1D sync at 1/1000th???
Yeah, I wonder what it is that's being captured. Technical sensor sync limitations aside, perhaps the camera is capturing UV or IR? Maybe just one color channel?
Could you try manually adjusting the WB on a RAW image of that shot and seeing if the colors of the birds display properly?
Edited on Aug 30, 2008 at 07:07 PM
ShaneEngelking
p.1 #9 · 1D sync at 1/1000th???
yes, that is precisely the reason that NBA photogs still use the original 1D series to link up to their strobes.
Aug 30, 2008 at 07:12 PM
SKYWESTR
p.1 #10 · 1D sync at 1/1000th???
Here's the shot after wb adjust and a little exposure comp. Looks like there's a little color there, but not much. Oops! that's the shot at 1/2500, however they all look the same right up to 1/16000.
Carl
  Canon EOS-1D    85 mm    f/2.0    1/2500 sec    3200 ISO    0.0 EV
Edited on Aug 30, 2008 at 09:07 PM
Aug 30, 2008 at 09:04 PM
Ariel Bravy
p.1 #11 · 1D sync at 1/1000th???
Here's my (totally unprofessional) look at what's happening.
For some reason, there's something unique and special about the red channel in the 1D. Many of us have raved about how wonderful the reds look coming out of this sensor.
For whatever reason, when you go past the sync speed, the red channel is still faintly able to detect light. There is also an ever-so-slight ability for the blue channel to appear as well, thus giving us the appearance of magenta. (Red + blue = purple. Red + a little blue = magenta... i believe).
We can see this when we WB to the magenta, neutralizing out the magenta cast. The red is gone, but there's still a hint of blueness left. The green is totally zapped out.
Why? Who knows. Looks kinda like an IR image though.
Aug 30, 2008 at 09:17 PM
Ariel Bravy
p.1 #12 · 1D sync at 1/1000th???
k, just for kicks, I went out w/ the 1D, 580ex off-shoe w/ the secondary E-TTL pins gaffered off, 100mm macro, and went around flashing the garden. These were shot at ISO 800-1600, f5.6-f11, 1/16000, flash very close to the subject at full power. Auto WB.
After twiddling around with the RAW WB a bit, it seems like it's effectively a B&W image with a very strong magenta cast. Shifting towards green doesn't really fix the color cast though. Basically you can apply any color cast you want, similar to sepia I suppose.
Aug 30, 2008 at 10:44 PM
Jonathan Knight
p.1 #13 · 1D sync at 1/1000th???
Very interesting, guys! This is very cool stuff you discovered. (okay....I'm sure you're not the FIRST to discover this, but I haven't seen or heard anything like this before)
Aug 31, 2008 at 05:00 AM
Ariel Bravy
p.1 #14 · 1D sync at 1/1000th???
Speaking of interesting, I just peeked in at one of the images at 100% to do some NR and noticed a weird digitalish pattern in the images. This is a 100% crop of the bottom left-hand side of the 4th image. The grain isn't like anything I've seen before.
ISO 800, -0.85 stops exposure compensation in post.
Edited on Aug 31, 2008 at 06:18 AM
Aug 31, 2008 at 06:16 AM
