sbeme Online Image Upload: On
p.1 #11 · texas state capitol building dome | |
Not sure if I like the politicized discussion on this forum, 'though I am quite tempted to chime in. And it's very interesting to see how our politics and values interesect or diverge from our photographer personalities.
At any rate, back to moody_blue....
Shot looks great. I think I'd need to spend some time and see a larger version to readily notice any seams, so that's good. Excellent job with lighting, symmetry, crop. I think the people are fine and do help with sense of scale. And besides, how would you get a shot like this without.
Handheld 18-55 kit lens images! Just goest to show you: fine images from less expensive lens with excellent technique.
As to printing, I agree with Scott S re posting to the Post-Processing/Printing forum. However, I'll share some questoins and thoughts as an advancing novice printer.
1. What size are you shooting for in the final print?
2. How will you make the print? Lab? Inkjet?
3. What kind of paper do you prefer? Matte doesnt require as much detail/dpi usually.
4. How close will the viewer likely be?
5. How large is the stitched file currently?
For smaller prints (eg 8x10, maybe a bit larger, you may want final resolution at approx 300dpi. The larger the print and the further the viewing distance, the more likely you can effectively drop the resolution down, probably in the neighborhood of 180+ dpi. Matte can be less. I suspect you have a huge file, so you probably dont have to worry about enough resolution.
While not a fan of Walmart, many printer choose to select a small area of the final print and print it full-size to check for problems. However, they generally do this on the final printer and a similar paper to catch issues with sharpness, color shifts, paper-ink interactions.
If you are having your print fulfilled, there are a number of excellent companies that are reasonalbe. WHCC, Adorama, MPIX all get consistently high reviews on dpreview and our own printing forum.
Personally, I'd go with a luster or semi-gloss paper on this image and forget about finding standard print sizes. It appears to be a great image that you are quite happy with overall and will be worth the investment to have it properly printed, matted, framed.
If you need more advice, let me know. I work on an Epson 3800.
Scott G
