Archive 2008 · 1dsmk3 long exposure noise
DanPBrown
p.1 #1 · 1dsmk3 long exposure noise
Could I get some opinions please. I just came back from Acadia National Park and I took some long night exposures there. It's my first time with the 1dsmk3, I had a 1dsmk2 prior to this camera. The noise seems a bit excessive. Here is the picture, 1 hour exposure iso 400,
http://i.pbase.com/o6/34/218934/1/102286646.Vxa5EO5y.JordanPond.jpg
Here is a 100% crop,
http://i.pbase.com/o6/34/218934/1/102286657.P5KnElAX.JordanPondcrop.jpg
Here is a crop from a 1 hour dark frame exposure that I took right after,
http://i.pbase.com/o6/34/218934/1/102286667.1fGpFqBJ.noisecrop.jpg
I don't remember my old camera being this bad. Is this normal for a 1dsmk3?
Thanks,
Edited on Aug 27, 2008 at 08:51 PM
Aug 27, 2008 at 08:49 PM
mpmendenhall
p.1 #2 · 1dsmk3 long exposure noise
From the look of the noise artifacts, did you have noise reduction turned on? Noise reduction can sometimes make a noisy image worse, converting unobtrusive uniform noise into sharp artifact spots on a flat, noiseless background. If you had NR on, you might want to try a long exposure without NR to see if the noise is better.
Aug 27, 2008 at 09:53 PM
stanj
p.1 #3 · 1dsmk3 long exposure noise
Because of the amplifier glow (lower left corner of your picture) I'd guess you had NR off (based on experience with my own 1Ds3). I'd suggest turning it on. It's a pain but makes it mildly better. Still, this is not the ideal camera for astro work...
Aug 27, 2008 at 10:01 PM
perfectpixel
p.1 #4 · 1dsmk3 long exposure noise
I don't know if any digital camera will give you a low noise 1 hour exposure.
There are some stacker applications used in astrophotography that will stack multiple shorter exposures to give you the same effect without the noise.
Aug 27, 2008 at 10:50 PM
Ron Hew
p.1 #5 · 1dsmk3 long exposure noise
Just wondering....why did you use ISO 400 for an hour exposure?
Aug 27, 2008 at 10:56 PM
DanPBrown
p.1 #6 · 1dsmk3 long exposure noise
Noise reduction was off. I also shot in raw and used ACR to process the image.
I used iso 400 to try and get some detail in the foliage.
Aug 28, 2008 at 06:00 AM
