Moderated by: guardian
Rules: One new topic per day
FM Forums | People Photography | Join Image Upload
cronic
Image Upload: Off
p.1 #1 · B&W Conversion...TIPS
hi folks...image attached was taken on a large ferris wheel in the Algarve, Portugal... Some PP has been done to remove the distractions...but i'm not happy with the B&W tones after conversion...especially when printed...image is uncropped
Before...
After...
Edited on Aug 27, 2008 at 06:56 AM
Aug 27, 2008 at 06:54 AM
jymloke
Image Upload: Off
p.1 #2 · B&W Conversion...TIPS
Add a layer, adjust your highlight and shadows to bring the contrast out. Add sepia tone or a yellower photo filter to it.
I normally apply some gaussian blur to a closeup like this, and set the opacity to about 40%. And then I use brush to brush off the blur on areas I want focus on. It looks great !!!
Send me the pic if you like, and I can post process it and post it back up and see if you like it
Aug 27, 2008 at 07:47 AM
ozhop
Image Upload: Off
p.1 #3 · B&W Conversion...TIPS
I believe that the background needs to be darker as it takes the eye away. Also add a little more contrast. If you have CS3 you can use the B&W adjustment layer and try out the yellow filter as a starting point and go from there.
Aug 27, 2008 at 07:55 AM
cronic
Image Upload: Off
p.1 #4 · B&W Conversion...TIPS
thanks for the comments...
Jymloke...PM for you...
Aug 27, 2008 at 08:02 AM
Cableaddict
Image Upload: On
p.1 #5 · B&W Conversion...TIPS
My first suggestion is to up the exposure on the color pic, first. In my (limited) experience, B&W conversion works best with pics that are almost over-exposed.
Then try other processes. I only have DxO's "Film Pack," but below are a few quick tweaks.
note; I tend to pick the crisp, detailed ones. You may prefer the darker, more muted type of B&W.
I also tend to go moderate-to-heavy on the grain.
Also, of course, results would be significantly better is done from a TIFF file.
1-3 are three done with your pic, as is. (too dark, IMO)
4-9 are done with your pic's exposure first boosted, a LOT.
Edited on Aug 27, 2008 at 08:08 AM
Cableaddict
Image Upload: On
p.1 #6 · B&W Conversion...TIPS
4 - 6
Aug 27, 2008 at 08:09 AM
Cableaddict
Image Upload: On
p.1 #7 · B&W Conversion...TIPS
7 - 9
Cableaddict
Image Upload: On
p.1 #8 · B&W Conversion...TIPS
OK, maybe some of those were a little TOO bright. ( ! )
I get carried away....... But better bright than boring, IMO.
-You might have to find a way to mask, or whatever it's called (I'm pretty new to PP) so you can only up the exposure on the humans, but not on the background.
Edited on Aug 27, 2008 at 08:13 AM
Aug 27, 2008 at 08:12 AM
bazlit
Image Upload: Off
p.1 #9 · B&W Conversion...TIPS
If you use Lightroom, this could be of a great help with B&W. I tried it and it works quite nicely.
http://www.layersmagazine.com/create-stunning-black-and-white-images-in-lightroom.html
Aug 27, 2008 at 09:18 AM
pamorl
Image Upload: Off
p.1 #10 · B&W Conversion...TIPS
Your original is underexposed. I find it easier to get a good b+w conversion from a good color image. I optimized the color image, then used the gradient map to do the conversion:
Before:
Aug 27, 2008 at 09:51 AM
cronic
Image Upload: Off
p.1 #11 · B&W Conversion...TIPS
pamorl... makes the image more lively...thank you
it was a tricky capture...in the shade due to canopy and sun high noon...
shame it lost the reflection in my wifes sun-glasses though...
Edited on Aug 27, 2008 at 10:14 AM
Aug 27, 2008 at 10:13 AM
pamorl
Image Upload: Off
p.1 #12 · B&W Conversion...TIPS
You're right...but that's an easy fix:
Aug 27, 2008 at 10:19 AM
Cableaddict
Image Upload: On
p.1 #13 · B&W Conversion...TIPS
Geez, cronic, I feel so invisible.
Well, you're welcome, anyway.
Edited on Aug 27, 2008 at 11:11 AM
Aug 27, 2008 at 11:09 AM
cronic
Image Upload: Off
p.1 #14 · B&W Conversion...TIPS
Sorry... i thought i replied to you...
the third bunch are perhaps better than the first/second...however the grain seems to lose some of the image sharpness...i know where you were trying to go with this...and i guess being JPEG in the first place limits the image processing...
Thanks for taking the time to look...and make suggestions...
Edited on Aug 27, 2008 at 12:19 PM
Aug 27, 2008 at 12:18 PM
photosenior
Image Upload: Off
p.1 #15 · B&W Conversion...TIPS
pamorl-
I like your conversion!
Can you explain how you did this is some greater detail?
Thanks!
Aug 27, 2008 at 04:35 PM
jeremy_clay
Buy and Sell: On
p.1 #16 · B&W Conversion...TIPS
I enjoy the range in pam's, here's a more range accurate one
Aug 27, 2008 at 04:39 PM
Sam Bortol
Image Upload: On
p.1 #17 · B&W Conversion...TIPS
here is an explanation from chuck that he sent me before. it helps a lot...all the credit goes to chuck(
canerino) lol.. .http://www.fredmiranda.com/forum/topic/664203/0#lastmessage
Edited on Aug 27, 2008 at 06:16 PM
jlukins
Buy and Sell: On
p.1 #18 · B&W Conversion...TIPS
I'm not sure what you don't like about your conversion. I think it's brilliant. Maybe bring down the black point a bit to slightly deepen the shadows, but I like it a lot.
Aug 27, 2008 at 07:46 PM
cronic
Image Upload: Off
p.1 #19 · B&W Conversion...TIPS
i'm liking the detail left in mine...esp in the shadows...but its 'flat'.
no doubt due to being under-exposed in the first place...
the responses have been very helpful...
Aug 28, 2008 at 07:16 AM
cronic
Image Upload: Off
p.1 #20 · B&W Conversion...TIPS
very very helpful link Sam ....thanks a million...
Aug 28, 2008 at 07:24 AM
pamorl
Image Upload: Off
p.1 #21 · B&W Conversion...TIPS
photosenior wrote:
pamorl-
Thanks!
Thank you, Photosenior Here ya go...
You can do a b+w conversion of a flat, underexposed color image using whatever method you like, then try to punch it up using various techniques, but in order to increase the contrast and give it a 3 dimensional look, the image quality is going to degrade if you have to push a flat b+w image very far.
For this reason I've always found that the best b+w conversions come from good quality color images. By "good quality", I mean having decent contrast and tonal range.
So, my first step in making this b+w conversion was to bring the color version up to an acceptable level first. This is what I meant when I said that I "optimized the color image". Sorry for the confusion
Here are the steps I used:
1 - The original image:
Here are the RGB channels of the original image. You can see that using the channel mixer (or any other conversion method) really wouldn't be useful at this point. All the channels are flat and lack contrast:
2 - So, I used curves and levels to adjust the color image and bring in some contrast:
Here are the RGB channels of the new adjusted (optimized) color image. As you can see, the channels now have depth and contrast. From this point, you can use just about any conversion method to get a good result. Even using the channel of your choice straight up would give acceptable results (select the channel, copy, then paste into a new layer).
3 - I use several conversion methods, but here I used a gradient map adjustment layer to do the conversion. It gives a nice smooth result. I didn't want it too contrasty at this point because I wanted to have room to polish it off. With that in mind, I left it slightly undercooked:
Every b+w conversion needs some final polishing to really make it shine. On this I burned and dodged using levels and curves to get the final result.
I noticed you mentioned something about the shadow detail, Cronic. Remember that everything is under your control. Also, to make an image pop and have depth, contrast is key. That means you need rich dark blacks for the light tones to play off. Too much shadow detail means less rich black areas to give depth, which leads to a flat looking image. It's a fine line you have to ride.
It's also important to distinguish between shadow detail and important shadow detail. Keep important shadow detail and crush the rest to prop up your lighter tones and give good contrast to the highlights. This will give your b+w's punch.
Here's the finished version with a little more shadow detail:
Hope this helps!
Pam
Edited on Aug 28, 2008 at 08:10 AM
Aug 28, 2008 at 08:03 AM
cronic
Image Upload: Off
p.1 #22 · B&W Conversion...TIPS
Pam...thank you for laying that all out...
Aug 28, 2008 at 08:22 AM
jymloke
Image Upload: Off
p.1 #23 · B&W Conversion...TIPS
Hi Cronic, here it is
Revamped Picture
I don't know how to insert picture like the above. Do I have to subscribe ?
Did channel correction like what Pam did above as well, with adjustments to contrast and brightness, as well as applying a Sepia photofilter onto it. I also applied Gaussian Blur to this to give the smooth edgy look, and decrease opacity for the layer to improve focus.
Lastly, use a brush with low opacity to highlight areas you would like sharpness improved.
Edited on Aug 29, 2008 at 04:22 AM
Aug 29, 2008 at 04:20 AM
cronic
Image Upload: Off
p.1 #24 · B&W Conversion...TIPS
thank you Jymloke... this conversion gains warmth and i like very much. Also thank you for explaining your PP.
cheers..!..cronic..!
Edited on Aug 29, 2008 at 07:59 AM
Aug 29, 2008 at 07:54 AM
Lost password?
